本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
Remove the two T10 12mm Torx screws from the left side panel.
即将完成!
结论
2等其他人完成本指南。
一条评论
You say no parts needed to be purchased. You have to buy a new scanner bulb if you’re replacing it.
