跳转到主内容
  1. Before disassembling your printer, be sure that the printer has been unplugged. Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Before disassembling your printer, be sure that the printer has been unplugged.
    • Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
    • Remove the two T10 12mm Torx screws from the left side panel.
  2. Firmly pull the the back of the side panel until it separates from the body of the printer. Rotate the side panel upwards while pulling it towards yourself to remove the panel.
    • Firmly pull the the back of the side panel until it separates from the body of the printer.
    • Rotate the side panel upwards while pulling it towards yourself to remove the panel.
  3. Rotate the printer 90 degrees clockwise. Grasp the paper tray and rotate it down.
    • Rotate the printer 90 degrees clockwise.
    • Grasp the paper tray and rotate it down.
    • Insert your fingers into the slot in the printer door and pull to rotate the gate down.
  4. Rotate the printer 90 degrees clockwise. Remove the two T10 12 mm Torx screws.
    • Remove the two T10 12 mm Torx screws.
    • Grasp both sides of the side panel and pull it forward to remove the panel.
  5. Rotate the printer 90 degrees counter clockwise. Lift the scanner lid to expose the scanner glass.
    • Rotate the printer 90 degrees counter clockwise.
    • Lift the scanner lid to expose the scanner glass.
  6. Remove the two T10 12 mm Torx screws.
    • Do not attempt to lift the top panel off the printer yet because it is still connected to the printer body by a cable.
  7. Rotate the printer 90 degrees counter clockwise. Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
    • Remove the front panel by grasping its front and pulling away from the printer.
    Änderung des Textes: die kleine Lasche verriegelt die kleine Frontblende: mit leichtem Druck Richtung “rechte Druckerseite entriegeln, gleichzeitig jene Blende nach vorn lösen.
    Garofalo - 回复
  8. Rotate the printer 90 degrees clockwise. Remove the cable connecting the top panel of the printer to the power button assembly.
    • Remove the cable connecting the top panel of the printer to the power button assembly.
  9. Carefully lift the top panel of the printer away from the printer body.
    • Carefully lift the top panel of the printer away from the printer body.
    nur die dünne weiße Abdeckung, die graue bleibt noch; zuerst hinten anheben, vorn ist mittig eine Nase zu lösen.
    Garofalo - 回复
  10. Set aside the top panel of the printer. Lift the scanner carriage vertically, being careful not to yank of the cables connecting it to the printer.
    • Set aside the top panel of the printer.
    • Lift the scanner carriage vertically, being careful not to yank of the cables connecting it to the printer.
  11. Flip the scanner carriage over to expose the connectors on the bottom. Carefully remove the small cable from the connector.
    • Flip the scanner carriage over to expose the connectors on the bottom.
    • Carefully remove the small cable from the connector.
    • Carefully remove the large cable from the connector.
  12. Remove the scanner carriage from the scanner tray and flip it upside down. Remove the two T10 12mm Torx screws.
    • Remove the scanner carriage from the scanner tray and flip it upside down.
    • Remove the two T10 12mm Torx screws.
    • Remove the scanner carriage from the scanner bulb.
结论
另外一个人完成了本指南。
Jim
于2011年10月06日注册
1,365 信誉积分
创作了10篇指南
团队
Cal Poly, Team 20-30, Maness Fall 2011 Cal Poly, Team 20-30, Maness Fall 2011 的会员
CPSU-MANESS-F11S20G30
4 名成员
创作了25篇指南
一条评论
You say no parts needed to be purchased. You have to buy a new scanner bulb if you’re replacing it.
ddaviddierlam - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 6
过去的30天: 16
总计 5,608
