工具
配件
没有特定配件。
Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
Remove the two T10 12mm Torx screws from the left side panel.
Set aside the top panel of the printer.
Remove the two T10 12 mm Torx screws from the top front of the printer
Set aside the ink cartridge carriage.
Remove the three T10 12mm Torx screws holding the paper guide to the printer body.
Lift the paper guide directly up to remove it and set it aside.
Rotate the printer 180 degrees and turn it up on to the front side, so that the back of the printer is facing up and the bottom facing you.
Be careful because the feed roller assembly is now loose, but it is still attached to the main body of the printer.
Push in the tab on the left side of the back panel and pull outward to remove the back panel.
Set aside the feed roller assembly.
Push down on the tab that is on the power and USB back panel and then away from the printer to remove the power and USB back panel.
6等其他人完成本指南。
3条评论
Muito boas elucidações das etapas para desmontagem da HP C3180
Excellent guide! You saved my printer. Thanks!
Dino Conte - 回复
