跳转到主内容
HP Photosmart Premium e-All-in-One C310a Scanning Light Replacement
你所需要的
  1. HP Photosmart Premium e-All-in-One C310a Scanning Light Replacement, Remove the Mounting Screws: 步骤 1 中的图像 1,2 HP Photosmart Premium e-All-in-One C310a Scanning Light Replacement, Remove the Mounting Screws: 步骤 1 中的图像 2,2
    • Tilt the touchscreen as far forward as possible.
    • Remove the two (2) 15mm T-10 Torx screws from behind the screen.
  2. HP Photosmart Premium e-All-in-One C310a Scanning Light Replacement, Separate the Touchpad from the Printer: 步骤 2 中的图像 1,1
    • Once the screws are removed, apply a steady upward force on the front bottom corners of the screen until it pops loose.
    • Be careful to not move the screen too far from the printer before disconnecting it. You may damage the connections within the printer if you do.
  3. HP Photosmart Premium e-All-in-One C310a Scanning Light Replacement, Disconnect the Ribbon Cables: 步骤 3 中的图像 1,2 HP Photosmart Premium e-All-in-One C310a Scanning Light Replacement, Disconnect the Ribbon Cables: 步骤 3 中的图像 2,2
    • Before removing the ribbon cable, flip the black bar up to unlock the cable. Grab the blue area of the cable near the connector and pull straight out of the socket.
    • Pull this plug straight out of the socket slowly.
    • Be careful when pulling out these ribbon cables. If you pull too hard or don't unlock the cable, you can damage the connection.
  4. HP Photosmart Premium e-All-in-One C310a Scanning Light Replacement, Remove the Touchpad: 步骤 4 中的图像 1,1
    • Once the ribbon cables have been removed, your screen should be free of the printer.
  5. HP Photosmart Premium e-All-in-One C310a Scanning Light Replacement, Remove the Scanning Cover: 步骤 5 中的图像 1,1
    • Lift the scanning cover until it is vertical.
    • Press on the cover near the two hinges.
  6. HP Photosmart Premium e-All-in-One C310a Scanning Light Replacement, Remove the Side Plates: 步骤 6 中的图像 1,2 HP Photosmart Premium e-All-in-One C310a Scanning Light Replacement, Remove the Side Plates: 步骤 6 中的图像 2,2
    • Pull the plate from the middle away from the printer until the tab is free.
    • Slide the plate towards the back of the printer until the latches are released.
    • Remove both side plates before you proceed.
  7. HP Photosmart Premium e-All-in-One C310a Scanning Light Replacement, Remove the Scanner Surface: 步骤 7 中的图像 1,1
    • Remove the five (5) 15mm T10 Torx screws.
    • Lift the scanner surface from the front where the screen was to remove it.
    • If you are only trying to clean the glass, stop here and follow the instructions in reverse order to reassemble your device.
  8. HP Photosmart Premium e-All-in-One C310a Scanning Light Replacement, Remove the Glass from the Scanner Surface: 步骤 8 中的图像 1,1
    • Make sure you are careful with the glass, as it can cut you if it breaks.
    • Apply force to the glass near where it is joined with the scanner surface.
    • Once the glass is removed, insert your new replacement glass and make sure it is firmly attached to the scanner surface.
  9. HP Photosmart Premium e-All-in-One C310a Scanning Light Replacement, Scanning Light: 步骤 9 中的图像 1,1
    • Remove the two ribbon cables from the scanning light.
  10. HP Photosmart Premium e-All-in-One C310a Scanning Light Replacement, Removal: 步骤 10 中的图像 1,1
    • The scanning light is now removed from the printer.
结论
另外一个人完成了本指南。
Andrew Schaub
于10/23/14注册
569 声望
创作了5篇指南
团队
Michigan Tech, Team 1-4, Lauer Fall 2014 Michigan Tech, Team 1-4, Lauer Fall 2014 的会员
MTU-LAUER-F14S1G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 675
