简介
This guide will show you how to replace the circuit board located behind the power button that handles powering on the printer.
你所需要的
Tilt the touchscreen as far forward as possible.
Remove the two (2) 15mm T-10 Torx screws from behind the screen.
Once the screws are removed, apply a steady upward force on the front bottom corners of the screen until it pops loose.
Before removing the ribbon cable, flip the black bar up to unlock the cable. Grab the blue area of the cable near the connector and pull straight out of the socket.
Pull this plug straight out of the socket slowly.
Once the ribbon cables have been removed, your screen should be free of the printer.
Lift the scanning cover until it is vertical.
Press on the cover near the two hinges.
Pull the plate from the middle away from the printer until the tab is free.
Slide the plate towards the back of the printer until the latches are released.
Remove both side plates before you proceed.
Remove the five (5) 15mm T10 Torx screws.
Lift the scanner surface from the front where the screen was to remove it.
Apply force to the glass near where it is joined with the scanner surface.
Once the glass is removed, insert your new replacement glass and make sure it is firmly attached to the scanner surface.
Pull the side of the cover plate away from the printer until it is off of the locking peg.
Pull the middle of the cover plate away from the printer until the tab in the middle is free.
Slide the cover plate to the right to disengage the latch.
Remove the 7mm T7 Torx screw holding the board to the cover panel.
Lift the power button board off the holding peg.
The power button board is now free from the cover panel.
