跳转到主内容
HP Photosmart Premium C309g Scanner Replacement
你所需要的
  1. HP Photosmart Premium C309g Scanner Replacement, Scanner: 步骤 1 中的图像 1,1
    • Open the top of the printer. The printer should appear as shown.
  2. HP Photosmart Premium C309g Scanner Replacement: 步骤 2 中的图像 1,2 HP Photosmart Premium C309g Scanner Replacement: 步骤 2 中的图像 2,2
    • Use the blue plastic opening tool to pry the trim pieces all the way around the printer.
    • Loosen the pieces around the edges before pulling to remove from the printer.
    • Pull the (4) trim pieces off and set them aside.
  3. HP Photosmart Premium C309g Scanner Replacement: 步骤 3 中的图像 1,2 HP Photosmart Premium C309g Scanner Replacement: 步骤 3 中的图像 2,2
    • Using the blue plastic opening tool, pull from the middle and then slide back to remove the side panels.
    • The side trim pieces need to be removed before the front trim pieces.
  4. HP Photosmart Premium C309g Scanner Replacement: 步骤 4 中的图像 1,1
    • Using the T9 Torx Security screwdriver bit, unscrew the five 12mm screws shown.
  5. HP Photosmart Premium C309g Scanner Replacement: 步骤 5 中的图像 1,1
    • The scanner flap is attached by a clip that can be dislodged by pulling it gently away from the printer.
    • Keeping the scanner flap upright, slide it toward the unattached clip in order to dislodge the second clip.
    • Both clips will come unattached and you can set the scanner flap aside.
  6. HP Photosmart Premium C309g Scanner Replacement: 步骤 6 中的图像 1,1
    • Lift the scanner glass piece from the printer and set it aside.
  7. HP Photosmart Premium C309g Scanner Replacement: 步骤 7 中的图像 1,2 HP Photosmart Premium C309g Scanner Replacement: 步骤 7 中的图像 2,2
    • Gently pick up the scanner piece as shown to see the bottom side and wiring.
  8. HP Photosmart Premium C309g Scanner Replacement: 步骤 8 中的图像 1,2 HP Photosmart Premium C309g Scanner Replacement: 步骤 8 中的图像 2,2
    • Gently remove the 2 wire ribbons shown by pulling them away from the scanner piece.
结论
Charles
于10/23/14注册
371 声望
创作了2篇指南
团队
Michigan Tech, Team 1-2, Lauer Fall 2014 Michigan Tech, Team 1-2, Lauer Fall 2014 的会员
MTU-LAUER-F14S1G2
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 1,355
