简介
This guide can be made easier with the help of a 2nd person, but it is not required.
Removing the hood involves removing 4 screws(one of which is placed such that it is difficult to access), and removing some ribbon cables.
Required Tools
- T-9 Screwdriver (T-9 may not work)
- Needle-Nose Pliers
工具
配件
没有特定配件。
First, begin by removing the printer's hood.
Open the printer's mouth by simply pulling down on it; there are 2 mouth pieces that need to be pulled down.
Adjust the flap covering the scanner upward, as shown.
To access and remove the fourth and final screw attaching the hood, the panel for the power button must be removed as follows:
Reach into the mouth of the printer and press on the small clip behind the power button. This allows the panel of the power button to be removed.
After pressing the clip, pull out the power button panel by pulling from right to left.
This step is easier with two people. Carefully have one person lift the hood of the printer 2-3 inches above where it was resting.
Remove the ribbon cables and wires attaching the motherboard (the only green PCB board) to the hood by gently pulling upward on them.
When all three cables are removed, lift the hood away from the printer and set it aside.
另外一个人完成了本指南。
