跳转到主内容
HP Photosmart D110a Power Button Replacement
你所需要的
  1. HP Photosmart D110a Power Button Replacement, Power Button: 步骤 1 中的图像 1,1
    • Open the printer's mouth by pulling the two mouth pieces down.
    • Lift the flap covering the scanner. When you are finished, the printer should appear as shown.
  2. HP Photosmart D110a Power Button Replacement: 步骤 2 中的图像 1,1
    • Remove the flap for the scanner by pulling lightly on the clip that attaches it to the printer.
    • The clip may be damaged by applying too much force.
  3. HP Photosmart D110a Power Button Replacement: 步骤 3 中的图像 1,3 HP Photosmart D110a Power Button Replacement: 步骤 3 中的图像 2,3 HP Photosmart D110a Power Button Replacement: 步骤 3 中的图像 3,3
    • Remove the three screws from the top of the printer using a T9 screwdriver as shown.
    • The screws are located in the far-left, far-right, and near-right corners of the printer, with respect to the front view.
  4. HP Photosmart D110a Power Button Replacement: 步骤 4 中的图像 1,1
    • Reach into the mouth of the printer and press the clip behind the power button to release the power button face.
  5. HP Photosmart D110a Power Button Replacement: 步骤 5 中的图像 1,1
    • A picture of the removed power button is provided to show the location of the clip that needs to be pressed.
    • After pressing the clip, pull out the face of the power button by sliding it from the right to the left side.
  6. HP Photosmart D110a Power Button Replacement: 步骤 6 中的图像 1,3 HP Photosmart D110a Power Button Replacement: 步骤 6 中的图像 2,3 HP Photosmart D110a Power Button Replacement: 步骤 6 中的图像 3,3
    • The power button face has a plastic holder that attaches the power button and the wireless button to the face plate using two slots.
    • Loosen the plastic holder by pulling the slots on the face plate away from the plastic holder.
    • Remove the plastic holder from the face plate after the slots are loosened.
  7. HP Photosmart D110a Power Button Replacement: 步骤 7 中的图像 1,3 HP Photosmart D110a Power Button Replacement: 步骤 7 中的图像 2,3 HP Photosmart D110a Power Button Replacement: 步骤 7 中的图像 3,3
    • The plastic holder secures the power button by two slots.
    • Using a spudger, push the holders inward to detach the button from the plastic holder.
结论
另外一个人完成了本指南。
Tim Wise
于04/01/11注册
173 声望
创作了7篇指南
团队
Cal Poly, Team 10-38, Forte Spring 2011 Cal Poly, Team 10-38, Forte Spring 2011 的会员
CPSU-FORTE-S11S10G38
5 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 3,735
