跳转到主内容
HP Photosmart D110a Motherboard Replacement
你所需要的
  1. HP Photosmart D110a Motherboard Replacement, Printer Hood Assembly: 步骤 1 中的图像 1,1
    • First, begin by removing the printer's hood.
    • Open the printer's mouth by simply pulling down on it; there are 2 mouth pieces that need to be pulled down.
    • Adjust the flap covering the scanner upward, as shown.
  2. HP Photosmart D110a Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the flap for the scanner. The flap is attached with two clips that can be dislodged by pulling lightly away from the printer.
  3. HP Photosmart D110a Motherboard Replacement: 步骤 3 中的图像 1,1
    • Locate the three screws on top of the printer.
    • The orange circle shows a fourth screw located behind the power panel. Directions to remove this screw are in a later step.
  4. HP Photosmart D110a Motherboard Replacement: 步骤 4 中的图像 1,3 HP Photosmart D110a Motherboard Replacement: 步骤 4 中的图像 2,3 HP Photosmart D110a Motherboard Replacement: 步骤 4 中的图像 3,3
    • Remove the three screws from the top of the printer with a T-9 screwdriver as shown.
  5. HP Photosmart D110a Motherboard Replacement: 步骤 5 中的图像 1,2 HP Photosmart D110a Motherboard Replacement: 步骤 5 中的图像 2,2
    • To access and remove the fourth and final screw attaching the hood, the panel for the power button must be removed as follows:
    • Reach into the mouth of the printer and press on the small clip behind the power button. This allows the panel of the power button to be removed.
    • A picture of the power button panel removed is provided to show the location of the clip that needs to be pressed.
    • After pressing the clip, pull out the power button panel by pulling from right to left.
  6. HP Photosmart D110a Motherboard Replacement: 步骤 6 中的图像 1,2 HP Photosmart D110a Motherboard Replacement: 步骤 6 中的图像 2,2
    • Remove the exposed screw that was covered by the power button panel.
    • Do not try and torque the screw from an angle. This will ruin the screw's head, and make it even more difficult to remove the screw. Only remove it as already described.
    • This screw is placed awkwardly. We found holding a T9 bit in a pair of needle nose pliers gave us enough leverage to pull it up.
  7. HP Photosmart D110a Motherboard Replacement: 步骤 7 中的图像 1,3 HP Photosmart D110a Motherboard Replacement: 步骤 7 中的图像 2,3 HP Photosmart D110a Motherboard Replacement: 步骤 7 中的图像 3,3
    • This step is easier with two people. Carefully have one person lift the hood of the printer 2-3 inches above where it was resting.
    • Remove the ribbon cables and wires attaching the motherboard (the only green PCB board) to the hood by gently pulling upward on them.
    • When all three cables are removed, lift the hood away from the printer and set it aside.
  8. HP Photosmart D110a Motherboard Replacement, Motherboard: 步骤 8 中的图像 1,2 HP Photosmart D110a Motherboard Replacement, Motherboard: 步骤 8 中的图像 2,2
    • Once the lid is removed, the motherboard (the only green PCB board) will become accessible.
  9. HP Photosmart D110a Motherboard Replacement: 步骤 9 中的图像 1,3 HP Photosmart D110a Motherboard Replacement: 步骤 9 中的图像 2,3 HP Photosmart D110a Motherboard Replacement: 步骤 9 中的图像 3,3
    • Use a T9 Torx Security screwdriver to remove the three screws securing the motherboard.
    • With your fingers or a spudger, remove the cables and ribbon cable by gently pulling them free from their sockets.
  10. HP Photosmart D110a Motherboard Replacement: 步骤 10 中的图像 1,1
    • Gently lift the mother board up from the printer and set it aside.
结论
2等其他人完成本指南。
Tim Wise
于04/01/11注册
173 声望
创作了7篇指南
团队
Cal Poly, Team 10-38, Forte Spring 2011 Cal Poly, Team 10-38, Forte Spring 2011 的会员
CPSU-FORTE-S11S10G38
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 20
总计 4,957
