跳转到主内容
HP Photosmart 935 Plastic Casing Replacement
你所需要的
  1. HP Photosmart 935 Plastic Casing Replacement, Batteries: 步骤 1 中的图像 1,2 HP Photosmart 935 Plastic Casing Replacement, Batteries: 步骤 1 中的图像 2,2
    • Flip the camera over so the bottom of the camera is facing you.
    • Turn the mode dial to the OFF position.
  2. HP Photosmart 935 Plastic Casing Replacement: 步骤 3 中的图像 1,2 HP Photosmart 935 Plastic Casing Replacement: 步骤 3 中的图像 2,2
    • Slide the bottom cover in the direction of the arrow to open it.
  3. HP Photosmart 935 Plastic Casing Replacement: 步骤 4 中的图像 1,1
    • Pull out the batteries.
  4. HP Photosmart 935 Plastic Casing Replacement, Plastic Casing: 步骤 5 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the two 4.7 mm screws in the bottom of the plastic casing.
  5. HP Photosmart 935 Plastic Casing Replacement: 步骤 6 中的图像 1,2 HP Photosmart 935 Plastic Casing Replacement: 步骤 6 中的图像 2,2
    • Remove the four 4.7 mm screws on the left side of the camera.
  6. HP Photosmart 935 Plastic Casing Replacement: 步骤 7 中的图像 1,2 HP Photosmart 935 Plastic Casing Replacement: 步骤 7 中的图像 2,2
    • Remove the four 4.7 mm screws on the opposite side of the camera.
  7. HP Photosmart 935 Plastic Casing Replacement: 步骤 8 中的图像 1,3 HP Photosmart 935 Plastic Casing Replacement: 步骤 8 中的图像 2,3 HP Photosmart 935 Plastic Casing Replacement: 步骤 8 中的图像 3,3
    • Use your thumbs to pry the case apart.
    • It is easiest to pry the case apart if you start at the bottom.
    • The case should come apart with minimal effort. If it doesn't, you can use a spudger or plastic opening tool to pry it open.
  8. HP Photosmart 935 Plastic Casing Replacement: 步骤 9 中的图像 1,1
    • This step requires a significant amount of force.
    • Pull the bottom half of the inner camera out of the case by half an inch. This may be difficult.
  9. HP Photosmart 935 Plastic Casing Replacement: 步骤 10 中的图像 1,2 HP Photosmart 935 Plastic Casing Replacement: 步骤 10 中的图像 2,2
    • While pulling the camera out of the case, note the small soft plastic cover on the side. This cover will detach from the rest of the device.
    • Once the bottom of the inner camera is pulled out, pull the device out completely.
    • Use a firm grasp when removing the device from the case for stability and control.
结论
Clay Young
于04/04/12注册
233 声望
创作了2篇指南
团队
Cal Poly, Team 15-13, Forte Spring 2012 Cal Poly, Team 15-13, Forte Spring 2012 的会员
CPSU-FORTE-S12S15G13
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 7
总计 1,732
