跳转到主内容
HP Pavillion dm4t-2100 Memory Card Replacement
你所需要的
  1. HP Pavillion dm4t-2100 Memory Card Replacement, Battery: 步骤 1 中的图像 1,2 HP Pavillion dm4t-2100 Memory Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Shut down the computer.
    • Shutting down the computer by holding power button can cause damage to computer.
    • Turn computer upside down so the base is facing upward.
  2. HP Pavillion dm4t-2100 Memory Card Replacement: 步骤 2 中的图像 1,3 HP Pavillion dm4t-2100 Memory Card Replacement: 步骤 2 中的图像 2,3 HP Pavillion dm4t-2100 Memory Card Replacement: 步骤 2 中的图像 3,3
    • Slide latch next to battery icon until battery pops up.
    • Pull the battery away from the computer until completely detached.
  3. HP Pavillion dm4t-2100 Memory Card Replacement, Memory Card: 步骤 3 中的图像 1,2 HP Pavillion dm4t-2100 Memory Card Replacement, Memory Card: 步骤 3 中的图像 2,2
    • Loosen two 5mm Phillips #1 screws securing plastic cover, until cover is detachable.
    • Slide cover toward empty battery area and remove it.
  4. HP Pavillion dm4t-2100 Memory Card Replacement: 步骤 4 中的图像 1,2 HP Pavillion dm4t-2100 Memory Card Replacement: 步骤 4 中的图像 2,2
    • Lift black cover overlaying memory chip.
    • Spread the tabs on each side of the memory slot to release the module.
    • Remove memory by pulling the memory out at an angle, until completely detached.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 261
