跳转到主内容
HP Pavillion dm1-3010nr Keyboard Replacement
你所需要的
  1. HP Pavillion dm1-3010nr Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the device over, so that the bottom cover is exposed.
    • Slide the black locking mechanism into its unlock position.
  2. HP Pavillion dm1-3010nr Keyboard Replacement: 步骤 2 中的图像 1,1
    • After unlocking the mechanism, slide the battery out of its compartment.
  3. HP Pavillion dm1-3010nr Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Remove the black bottom cover by using your fingernails or a thin flat tool.
  4. HP Pavillion dm1-3010nr Keyboard Replacement: 步骤 4 中的图像 1,2 HP Pavillion dm1-3010nr Keyboard Replacement: 步骤 4 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove three 5mm screws securing the keyboard.
    • The screws to be removed are circled in red in the picture provided.
    • Make sure to place the screws somewhere safe like on top of a magnet.
  5. HP Pavillion dm1-3010nr Keyboard Replacement: 步骤 5 中的图像 1,1
    • Flip the laptop so that they keyboard is facing you.
    • Use a thin and flat metal to carefully lift up the top side of the keyboard and separate it from the top cover.
  6. HP Pavillion dm1-3010nr Keyboard Replacement: 步骤 6 中的图像 1,2 HP Pavillion dm1-3010nr Keyboard Replacement: 步骤 6 中的图像 2,2
    • Now you will see the keyboard cable connector attached to a locking tab.
    • Lift up the locking tab with a thin and flat screwdriver or your fingernail.
    • The locking tab will open up at a 90 degree angle.
    • Pull the keyboard cable from the connector.
结论
Rosalia Olga Dupont Ayala
于10/22/18注册
210 声望
撰写一个指南
团队
UC Davis, Team S7-G1, Lore Fall 2018 UC Davis, Team S7-G1, Lore Fall 2018 的会员
UCD-LORE-F18S7G1
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 9
总计 637
