跳转到主内容
HP Pavillion dm1-3010nr Cooling Fan Replacement
你所需要的
  1. HP Pavillion dm1-3010nr Cooling Fan Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the device over, so that the bottom cover is exposed.
    • Slide the black locking mechanism into its unlock position.
  2. HP Pavillion dm1-3010nr Cooling Fan Replacement: 步骤 2 中的图像 1,1
    • After unlocking the mechanism, slide the battery out of its compartment.
  3. HP Pavillion dm1-3010nr Cooling Fan Replacement, Cooling Fan: 步骤 3 中的图像 1,1
    • With the battery removed, the bottom cover can be opened with your hand.
  4. HP Pavillion dm1-3010nr Cooling Fan Replacement: 步骤 4 中的图像 1,2 HP Pavillion dm1-3010nr Cooling Fan Replacement: 步骤 4 中的图像 2,2
    • Use a screwdriver from your iFixit Toolkit to remove the two 5mm Phillips #0 screws shown in each picture.
    • Use tweezers to carefully remove the fan's power cable from the motherboard. The cable can be seen in the second picture.
  5. HP Pavillion dm1-3010nr Cooling Fan Replacement: 步骤 5 中的图像 1,1
    • After removing the screws and unplugging the wire, remove the fan.
结论
Amitpal Gill
于10/22/18注册
375 声望
创作了3篇指南
团队
UC Davis, Team S7-G1, Lore Fall 2018 UC Davis, Team S7-G1, Lore Fall 2018 的会员
UCD-LORE-F18S7G1
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 5
总计 580
