跳转到主内容
HP Pavillion G7-2235DX Keyboard Replacement
你所需要的
  1. HP Pavillion G7-2235DX Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Before beginning, make sure the computer is turned off and the charger is disconnected.
    • Flip the computer over, so that the bottom is facing up.
  2. HP Pavillion G7-2235DX Keyboard Replacement: 步骤 2 中的图像 1,1
    • To remove the battery, slide the battery switch to the left.
  3. HP Pavillion G7-2235DX Keyboard Replacement: 步骤 3 中的图像 1,2 HP Pavillion G7-2235DX Keyboard Replacement: 步骤 3 中的图像 2,2
    • Using a PH Screwdriver, remove the three 7.25mm screws located on the bottom panel.
    • After removing all screws, remove the panel by sliding down.
  4. HP Pavillion G7-2235DX Keyboard Replacement: 步骤 4 中的图像 1,1
    • Using a PH screwdriver, remove the screw adjacent to the white labels.
    • There is a keyboard icon next to the screw
  5. HP Pavillion G7-2235DX Keyboard Replacement: 步骤 5 中的图像 1,1
    • Flip the laptop over, and open it.
  6. HP Pavillion G7-2235DX Keyboard Replacement: 步骤 6 中的图像 1,1
    • Using a plastic spudger, pry beneath the keyboard near the "delete" key, and pop the keyboard up from the laptop.
    • From the open gap, continue to pry around the perimeter of the keyboard, separating it from the laptop.
  7. HP Pavillion G7-2235DX Keyboard Replacement: 步骤 7 中的图像 1,2 HP Pavillion G7-2235DX Keyboard Replacement: 步骤 7 中的图像 2,2
    • Using both hands, carefully lift the keyboard off of the laptop.
    • There may be a ribbon attached. If so, gently pull the ribbon cable up and away from the connector.
结论
5等其他人完成本指南。
Bre'Anna Sanders
于10/11/16注册
113 声望
创作了2篇指南
团队
USF Tampa, Team 1-7, Leahy Fall 2016 USF Tampa, Team 1-7, Leahy Fall 2016 的会员
USFT-LEAHY-F16S1G7
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 80
总计 2,474
