跳转到主内容
HP Pavilion zd8000 Switch Cover Replacement
你所需要的
  1. HP Pavilion zd8000 Switch Cover Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 Switch Cover Replacement: 步骤 2 中的图像 1,2 HP Pavilion zd8000 Switch Cover Replacement: 步骤 2 中的图像 2,2
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 Switch Cover Replacement, WiFi Card Cables: 步骤 3 中的图像 1,2 HP Pavilion zd8000 Switch Cover Replacement, WiFi Card Cables: 步骤 3 中的图像 2,2
    • Unscrew the four 8mm Philips screws marked with an icon resembling a stacks of discs.
    • Lift the cover from the right to remove it.
  4. HP Pavilion zd8000 Switch Cover Replacement: 步骤 4 中的图像 1,2 HP Pavilion zd8000 Switch Cover Replacement: 步骤 4 中的图像 2,2
    • Use tweezers to detach the grey and black cables connected to the green WiFi card.
  5. HP Pavilion zd8000 Switch Cover Replacement, Switch Cover: 步骤 5 中的图像 1,2 HP Pavilion zd8000 Switch Cover Replacement, Switch Cover: 步骤 5 中的图像 2,2
    • Place the laptop face-down and rotate it 180 degrees so the vents are facing you.
    • Remove the five 8mm Philips screws. Three are on the black base and two are near the hinges.
  6. HP Pavilion zd8000 Switch Cover Replacement: 步骤 6 中的图像 1,1
    • Flip the laptop over.
    • Fully open the laptop.
  7. HP Pavilion zd8000 Switch Cover Replacement: 步骤 7 中的图像 1,3 HP Pavilion zd8000 Switch Cover Replacement: 步骤 7 中的图像 2,3 HP Pavilion zd8000 Switch Cover Replacement: 步骤 7 中的图像 3,3
    • Rotate it so the display is on your right and the keyboard is on your left.
    • Lift the switch cover firmly but slowly so you do not snap it.
    • Lift the switch cover carefully from one end while sliding the spudger between the switch cover and the laptop to separate them.
    • The switch cover should easily separate from the laptop as you run the spudger through.
结论
另外一个人完成了本指南。
Allie Menard
于04/12/11注册
820 声望
创作了13篇指南
团队
Cal Poly, Team 24-56, Amido Spring 2011 Cal Poly, Team 24-56, Amido Spring 2011 的会员
CPSU-AMIDO-S11S24G56
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,088
