跳转到主内容
HP Pavilion zd8000 Keyboard Replacement
你所需要的
  1. HP Pavilion zd8000 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the battery release latch towards you.
  2. HP Pavilion zd8000 Keyboard Replacement: 步骤 2 中的图像 1,2 HP Pavilion zd8000 Keyboard Replacement: 步骤 2 中的图像 2,2
    • Pull up on the battery to remove it.
  3. HP Pavilion zd8000 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,1
    • Remove the two 8mm Philips screws marked “K” on the bottom of the laptop.
  4. HP Pavilion zd8000 Keyboard Replacement: 步骤 4 中的图像 1,2 HP Pavilion zd8000 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Flip the laptop over and open the screen.
    • Push up on the four latches located at the top of the keyboard with the spudger to release them.
  5. HP Pavilion zd8000 Keyboard Replacement: 步骤 5 中的图像 1,2 HP Pavilion zd8000 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Lift the keyboard carefully because it is attached to the motherboard by a ribbon cable.
    • Lift the top of the keyboard towards you. Then, while keeping the keyboard at an angle, lift it towards the display.
  6. HP Pavilion zd8000 Keyboard Replacement: 步骤 6 中的图像 1,2 HP Pavilion zd8000 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Rotate the keyboard so that the bottom is visible.
    • With the keyboard lifted, locate the blue-striped tab on the underside of the black ribbon cable.
    • Pull the tab towards you to release the keyboard from the laptop.
结论
Allie Menard
于04/12/11注册
820 声望
创作了13篇指南
团队
Cal Poly, Team 24-56, Amido Spring 2011 Cal Poly, Team 24-56, Amido Spring 2011 的会员
CPSU-AMIDO-S11S24G56
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 4,082
