跳转到主内容
HP Pavilion x360 m3-u103dx Motherboard Replacement
你所需要的
  1. HP Pavilion x360 m3-u103dx Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Power the device off.
    • Flip the device over.
    • Using the plastic spudger, remove the rubber bumper to reveal 5 screws.
  2. HP Pavilion x360 m3-u103dx Motherboard Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips screwdriver, remove 10 screws from the back plate.
    • Five 2.4 x 5.7 mm screws.
    • Five 2.8 x 5.0 mm screws.
  3. HP Pavilion x360 m3-u103dx Motherboard Replacement: 步骤 3 中的图像 1,3 HP Pavilion x360 m3-u103dx Motherboard Replacement: 步骤 3 中的图像 2,3 HP Pavilion x360 m3-u103dx Motherboard Replacement: 步骤 3 中的图像 3,3
    • Using the plastic opening tool, pry the keyboard upwards at the opening shown.
    • Then, using the metal spudger, pry around the rest of the keyboard until it is completely free.
    • Slowly, lift the entire keyboard up and away from the screen to reveal the connections and internals.
    • The connector ribbons can be damaged if the keyboard is lifted too high.
  4. HP Pavilion x360 m3-u103dx Motherboard Replacement: 步骤 4 中的图像 1,2 HP Pavilion x360 m3-u103dx Motherboard Replacement: 步骤 4 中的图像 2,2
    • Using the black nylon spudger, lift the retaining clip for each ribbon shown.
    • Lift the keyboard out of the device and out of the way.
  5. HP Pavilion x360 m3-u103dx Motherboard Replacement: 步骤 5 中的图像 1,3 HP Pavilion x360 m3-u103dx Motherboard Replacement: 步骤 5 中的图像 2,3 HP Pavilion x360 m3-u103dx Motherboard Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using a J000 screwdriver, remove 9 screws from the motherboard.
    • Using a Y1 screwdriver, remove the 10th screw from the top of the motherboard.
    • Tweezers can be helpful to pull screws from tight areas.
    • Grounding bracelets can prevent static from harming delicate electronics.
  6. HP Pavilion x360 m3-u103dx Motherboard Replacement: 步骤 6 中的图像 1,2 HP Pavilion x360 m3-u103dx Motherboard Replacement: 步骤 6 中的图像 2,2
    • Using a spudger, flip the retaining clips for these two ribbons and gently pull them away from their sockets.
    • Using tweezers, gently pull this connector away from its socket.
  7. HP Pavilion x360 m3-u103dx Motherboard Replacement: 步骤 7 中的图像 1,2 HP Pavilion x360 m3-u103dx Motherboard Replacement: 步骤 7 中的图像 2,2
    • Gently lift the entire motherboard while tilting it to the left side of the laptop.
    • Disconnect the final plug from underneath the motherboard.
    • Lift the old motherboard from the laptop completely.
结论
Nicholas Bassett
于09/03/19注册
145 声望
撰写一个指南
团队
IUPUI, Team S1-G2, Hovde Fall 2019 IUPUI, Team S1-G2, Hovde Fall 2019 的会员
IUPUI-HOVDE-F19S1G2
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 11
总计 548
