跳转到主内容
HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement
你所需要的
  1. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Power off Device.
    • Working device while it is powered on may cause damage to laptop or electric shock.
  2. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: 步骤 2 中的图像 1,1
    • Flip over laptop
    • Remove the rubber foot with a Metal Spudger
  3. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: 步骤 3 中的图像 1,1
    • Remove the screws from the bottom of the laptop using a Phillips 00 Screwdriver.
    • 5 Phillips 2.4 x 5.7 mm screws.
    • 5 Phillips 2.0 x 5.0 mm screws.
    • Make sure to keep different screw types separated.
  4. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: 步骤 4 中的图像 1,3 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: 步骤 4 中的图像 2,3 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: 步骤 4 中的图像 3,3
    • Flip the laptop over to screen and keyboard side.
    • Using a Metal Spudger pop open keyboard from base of laptop.
    • Be cautious of three wires on the inside of the keyboard connecting it to the motherboard.
  5. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: 步骤 5 中的图像 1,2 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: 步骤 5 中的图像 2,2
    • Disconnect the three connected cable ribbons connected to the motherboard by gently pulling them out of their connectors.
  6. HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: 步骤 6 中的图像 1,2 HP Pavilion x360 m3-u103dx HP Pavilion x360 m3-u103dx Keyboard Replacement: 步骤 6 中的图像 2,2
    • After ribbon cables have been disconnected, carefully lift up keyboard to disconnect from base of laptop.
结论
另外一个人完成了本指南。
一条评论
what if it is just one key that isnt working. my enter key doesn’t work and it’s very frustrating
k.kolish2493 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 726
