跳转到主内容
HP Pavilion x360 m3-u103dx Daughterboard Replacement
你所需要的
  1. HP Pavilion x360 m3-u103dx Daughterboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Shut down the computer.
    • Disconnect the power and all external devices connected to the computer.
    • Working on your device while it is turned on may result in electric shock.
  2. HP Pavilion x360 m3-u103dx Daughterboard Replacement: 步骤 2 中的图像 1,2 HP Pavilion x360 m3-u103dx Daughterboard Replacement: 步骤 2 中的图像 2,2
    • Use a Metal Spudger and remove the rubber foot closet from the bottom of the laptop.
  3. HP Pavilion x360 m3-u103dx Daughterboard Replacement: 步骤 3 中的图像 1,1
    • Remove all of the screws located on the bottom of the laptop:
    • 5 Phillips 2.4 x 5.7 mm screws
    • 5 Phillips 2.0 x 5.0 mm screws
    • Make special note of each screw and screw lock size and location during removal and replacement.
  4. HP Pavilion x360 m3-u103dx Daughterboard Replacement: 步骤 4 中的图像 1,1
    • Turn the computer over onto its base, with the computer open and the keyboard facing upward.
  5. HP Pavilion x360 m3-u103dx Daughterboard Replacement: 步骤 5 中的图像 1,2 HP Pavilion x360 m3-u103dx Daughterboard Replacement: 步骤 5 中的图像 2,2
    • The keyboard is attached internally by clips. Use a small amount of force when removing the keyboard.
    • Use the Plastic Opening Tool to separate the keyboard from the base of the laptop.
  6. HP Pavilion x360 m3-u103dx Daughterboard Replacement: 步骤 6 中的图像 1,1
    • Raise the keyboard slightly to access the touch pad and keyboard cables.
    • Raising the keyboard too far or with excessive force may cause damage to the keyboard, touch pad cables, or their connectors.
  7. HP Pavilion x360 m3-u103dx Daughterboard Replacement: 步骤 7 中的图像 1,1
    • Disconnect the ribbon cables attaching the touch pad and keyboard to the system board (motherboard).
    • Using the Heavy-Duty Spudger lift up the plastic locks connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to pull it out from the lock on the motherboard.
  8. HP Pavilion x360 m3-u103dx Daughterboard Replacement: 步骤 8 中的图像 1,1
    • Lift the keyboard away from the base of the laptop.
  9. HP Pavilion x360 m3-u103dx Daughterboard Replacement, Battery: 步骤 9 中的图像 1,1
    • Using the Phillips 00 Screwdriver, remove 6 Phillips 2.0 x 4.6 mm screws from the perimeter of the battery.
  10. HP Pavilion x360 m3-u103dx Daughterboard Replacement: 步骤 10 中的图像 1,1
    • Carefully lift the battery up from lower right corner and disconnect it from the motherboard.
  11. HP Pavilion x360 m3-u103dx Daughterboard Replacement, Daughterboard: 步骤 11 中的图像 1,2 HP Pavilion x360 m3-u103dx Daughterboard Replacement, Daughterboard: 步骤 11 中的图像 2,2
    • Carefully disconnect the lower ribbon cable by pry the locking bar of the ZIF connector up with a spudger and pulling the cable loose.
  12. HP Pavilion x360 m3-u103dx Daughterboard Replacement: 步骤 12 中的图像 1,2 HP Pavilion x360 m3-u103dx Daughterboard Replacement: 步骤 12 中的图像 2,2
    • Use the same procedure to disengage the skinnier ribbon cable just above the first: pry up the locking bar of the ZIF connector and slide out the cable.
  13. HP Pavilion x360 m3-u103dx Daughterboard Replacement: 步骤 13 中的图像 1,2 HP Pavilion x360 m3-u103dx Daughterboard Replacement: 步骤 13 中的图像 2,2
    • Remove the two screws with a Phillips #00 screwdriver.
    • Remove the daughterboard.
结论
Victor Samuel
于01/08/15注册
199 声望
创作了2篇指南
团队
IUPUI, Team S2-G2, Wilson Summer 2019 IUPUI, Team S2-G2, Wilson Summer 2019 的会员
IUPUI-WILSON-SU19S2G2
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 16
总计 630
