跳转到主内容
HP Pavilion x360 m3-u103dx Battery Replacement
你所需要的
  1. HP Pavilion x360 m3-u103dx Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Power off device.
    • Flip the laptop over.
    • Working on your device while its powered on may cause damage to your device.
  2. HP Pavilion x360 m3-u103dx Battery Replacement: 步骤 2 中的图像 1,1
    • Remove rubber foot closest to computer hinge with a Metal Spudger.
  3. HP Pavilion x360 m3-u103dx Battery Replacement: 步骤 3 中的图像 1,1
    • Remove all screws from base using a Phillips head 00 screwdriver.
    • 5 Phillip 2.4 x 5.7 mm screws.
    • 5 Phillips 2.8 x 5.0 mm screws.
  4. HP Pavilion x360 m3-u103dx Battery Replacement: 步骤 4 中的图像 1,3 HP Pavilion x360 m3-u103dx Battery Replacement: 步骤 4 中的图像 2,3 HP Pavilion x360 m3-u103dx Battery Replacement: 步骤 4 中的图像 3,3
    • Open computer and pry open keyboard panel using the Metal Spudger. Apply little pressure then increase until keyboard pops away from motherboard.
    • Be careful not to pull or disconnect ribbon cables first.
  5. HP Pavilion x360 m3-u103dx Battery Replacement: 步骤 5 中的图像 1,2 HP Pavilion x360 m3-u103dx Battery Replacement: 步骤 5 中的图像 2,2
    • Gently lift the keyboard on the mouse pad side, but do not remove.
    • The keyboard is still connected by three ribbon cables.
    • Remove three connected ribbon wires connecting keyboard to frame by gently disconnecting them from the motherboard.
  6. HP Pavilion x360 m3-u103dx Battery Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove six screws around the battery.
    • 6 Phillips 2.0 x 4.6 mm screws.
  7. HP Pavilion x360 m3-u103dx Battery Replacement: 步骤 7 中的图像 1,2 HP Pavilion x360 m3-u103dx Battery Replacement: 步骤 7 中的图像 2,2
    • Gently lift the battery up and away from the casing.
    • Carefully remove the battery from its connecting port.
结论
另外一个人完成了本指南。
一条评论
Can i use the laptop even without a battery??
PAPISSS PH - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 40
总计 6,845
