跳转到主内容
HP Pavilion x360 m1-u001dx Battery Replacement
你所需要的
  1. HP Pavilion x360 m1-u001dx Battery Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Power off your device and disconnect all external devices connected to the laptop.
    • Working on your device while it is powered on may cause damage to the laptop or result in electric shock.
  2. HP Pavilion x360 m1-u001dx Battery Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop over and remove the rubber foot with a Metal Spudger.
  3. HP Pavilion x360 m1-u001dx Battery Replacement: 步骤 3 中的图像 1,1
    • Remove the screws from the bottom of the laptop with a Phillips 00 Screwdriver.
    • 5 Phillips 2.4 x 5.7 mm screws
    • 7 Phillips 2.0 x 5.0 mm screws
    • Keep the different sized screws separate for future replacement.
  4. HP Pavilion x360 m1-u001dx Battery Replacement: 步骤 4 中的图像 1,3 HP Pavilion x360 m1-u001dx Battery Replacement: 步骤 4 中的图像 2,3 HP Pavilion x360 m1-u001dx Battery Replacement: 步骤 4 中的图像 3,3
    • Flip the laptop back over and open it; the keyboard should be facing upwards.
    • Using the Plastic Opening Tool, separate the keyboard from the base of the laptop.
    • The keyboard is connected to the motherboard with cable ribbons, so be very gentle and careful when lifting the keyboard.
  5. HP Pavilion x360 m1-u001dx Battery Replacement: 步骤 5 中的图像 1,3 HP Pavilion x360 m1-u001dx Battery Replacement: 步骤 5 中的图像 2,3 HP Pavilion x360 m1-u001dx Battery Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    Heavy-Duty Spudger
    购买
    • Raising the keyboard, disconnect the first of two cable ribbons with the Heavy-Duty Spudger.
    • Gently flip up the white plastic lock connecting the ribbon cable to the motherboard.
    • Use the blue plastic tab on the ribbon cable to disconnect the ribbon cable from the lock.
  6. HP Pavilion x360 m1-u001dx Battery Replacement: 步骤 6 中的图像 1,2 HP Pavilion x360 m1-u001dx Battery Replacement: 步骤 6 中的图像 2,2
    • Gently flip up the white plastic lock connecting the second ribbon cable to the motherboard with the Heavy-Duty Spudger.
    • Use the blue purple tab on the ribbon cable to disconnect the ribbon cable from the lock.
  7. HP Pavilion x360 m1-u001dx Battery Replacement: 步骤 7 中的图像 1,2 HP Pavilion x360 m1-u001dx Battery Replacement: 步骤 7 中的图像 2,2
    • After the ribbon cables are disconnected, gently lift up the keyboard to disconnect it from the base of the laptop.
  8. HP Pavilion x360 m1-u001dx Battery Replacement, Battery: 步骤 8 中的图像 1,3 HP Pavilion x360 m1-u001dx Battery Replacement, Battery: 步骤 8 中的图像 2,3 HP Pavilion x360 m1-u001dx Battery Replacement, Battery: 步骤 8 中的图像 3,3
    • Remove the screws from the perimeter of the battery with a Phillips 00 Screwdriver.
    • 3 Phillips 2.0 x 4.6 mm screws
  9. HP Pavilion x360 m1-u001dx Battery Replacement: 步骤 9 中的图像 1,2 HP Pavilion x360 m1-u001dx Battery Replacement: 步骤 9 中的图像 2,2
    • Holding the lower right corner, gently lift up the battery to disconnect it from the motherboard.
结论
Katie
于09/21/17注册
549 声望
创作了5篇指南
一条评论
What is the usual expected backup time for this battery?
Thanks for the instructions.
Nipu011 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 22
总计 2,316
