跳转到主内容
HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement
你所需要的
  1. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): 步骤 1 中的图像 1,3 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): 步骤 1 中的图像 2,3 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement, Solid-State Drive (SSD): 步骤 1 中的图像 3,3
    • Turn off the device and set it upside down. Orient the hinges away from you.
    • Wedge the opening pick under the grip. Lift the end of the grip.
    • Pull the grip off all the way. Repeat for the second grip.
  2. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: 步骤 2 中的图像 1,3 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: 步骤 2 中的图像 2,3 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: 步骤 2 中的图像 3,3
    • Use PH0 to remove the 3mm screw from the center bottom.
    • Use PH1 to remove the 6mm screw from all four corners.
  3. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: 步骤 3 中的图像 1,3 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: 步骤 3 中的图像 2,3 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: 步骤 3 中的图像 3,3
    • Use the opening pick to separate the back panel from the device.
    • Begin near the hinge and carefully follow the perimeter until you have taken the pick around all four sides.
    • The back panel will come loose once the pick has been around the whole edge of the device.
    • Lift the panel off.
  4. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: 步骤 4 中的图像 1,2 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: 步骤 4 中的图像 2,2
    • Pinch and lift the small WLAN plate.
  5. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: 步骤 5 中的图像 1,1
    • Use PH1 to remove the 2.5mm holding screw.
  6. HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: 步骤 6 中的图像 1,2 HP Pavilion x360 Convertible 14-dw1025nr Solid-State Drive (SSD) Replacement: 步骤 6 中的图像 2,2
    • Pull the SSD out and up, away from the connector.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 31
总计 462
