跳转到主内容
HP Pavilion x360 15t-br000 Motherboard Replacement
你所需要的
  1. HP Pavilion x360 15t-br000 Motherboard Replacement, Keyboard Panel: 步骤 1 中的图像 1,3 HP Pavilion x360 15t-br000 Motherboard Replacement, Keyboard Panel: 步骤 1 中的图像 2,3 HP Pavilion x360 15t-br000 Motherboard Replacement, Keyboard Panel: 步骤 1 中的图像 3,3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Motherboard Replacement: 步骤 2 中的图像 1,3 HP Pavilion x360 15t-br000 Motherboard Replacement: 步骤 2 中的图像 2,3 HP Pavilion x360 15t-br000 Motherboard Replacement: 步骤 2 中的图像 3,3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Motherboard Replacement, Battery: 步骤 3 中的图像 1,1
    • Disconnect the battery cable from the device.
  4. HP Pavilion x360 15t-br000 Motherboard Replacement: 步骤 4 中的图像 1,2 HP Pavilion x360 15t-br000 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the seven Phillips #0 4.5 mm screws.
    • Remove the battery from the device.
  5. HP Pavilion x360 15t-br000 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,2 HP Pavilion x360 15t-br000 Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Disconnect the five cable connections to the motherboard.
  6. HP Pavilion x360 15t-br000 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Unscrew the nine 3mm mounting screws on the motherboard using the Phillips #0 screwdriver.
  7. HP Pavilion x360 15t-br000 Motherboard Replacement: 步骤 7 中的图像 1,2 HP Pavilion x360 15t-br000 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Lift the motherboard carefully then remove the motherboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 295
