跳转到主内容
HP Pavilion x360 15t-br000 Keyboard Replacement
你所需要的
  1. HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard Panel: 步骤 1 中的图像 1,3 HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard Panel: 步骤 1 中的图像 2,3 HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard Panel: 步骤 1 中的图像 3,3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Keyboard Replacement: 步骤 2 中的图像 1,3 HP Pavilion x360 15t-br000 Keyboard Replacement: 步骤 2 中的图像 2,3 HP Pavilion x360 15t-br000 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,3 HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,3 HP Pavilion x360 15t-br000 Keyboard Replacement, Keyboard: 步骤 3 中的图像 3,3
    • Remove the two tapes of connected with the track board and the keyboard panel.
    • Remove the seven 2mm screws using the Phillips #0 screwdriver.
    • Remove the trackpad from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 441
