跳转到主内容
HP Pavilion x360 15t-br000 Hard Drive Replacement
你所需要的
  1. HP Pavilion x360 15t-br000 Hard Drive Replacement, Keyboard Panel: 步骤 1 中的图像 1,3 HP Pavilion x360 15t-br000 Hard Drive Replacement, Keyboard Panel: 步骤 1 中的图像 2,3 HP Pavilion x360 15t-br000 Hard Drive Replacement, Keyboard Panel: 步骤 1 中的图像 3,3
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Hard Drive Replacement: 步骤 2 中的图像 1,3 HP Pavilion x360 15t-br000 Hard Drive Replacement: 步骤 2 中的图像 2,3 HP Pavilion x360 15t-br000 Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Use the Phillips #0 screwdriver to remove four screws from the hard drive.
    • Remove the hard drive from the device.
    • At the time of creating this guide, the hard drive was not present in the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 10
总计 798
