跳转到主内容
HP Pavilion x360 14m-cd0005dx Motherboard Replacement
你所需要的
  1. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 2 中的图像 1,1
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 3 中的图像 1,2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 3 中的图像 2,2
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 4 中的图像 1,2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 5 中的图像 1,3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 5 中的图像 2,3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 5 中的图像 3,3
    • Using the opening tool, carefully remove the bottom cover from the device.
  6. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Battery: 步骤 6 中的图像 1,3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Battery: 步骤 6 中的图像 2,3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Battery: 步骤 6 中的图像 3,3
    • Use a #00 Phillips screwdriver to remove:
    • Six 2.5 mm screws
  7. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 7 中的图像 1,2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 7 中的图像 2,2
    • Carefully lift from the base and remove the battery.
  8. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Heat Sink and Fan: 步骤 8 中的图像 1,1
    • Remove the tape that secures the fan to the computer.
  9. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 9 中的图像 1,2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 9 中的图像 2,2
    • Find the fan cable
    • Use the Reverse Tweezers to unplug the fan cable
  10. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 10 中的图像 1,3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 10 中的图像 2,3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 10 中的图像 3,3
    • Remove all screws securing the fan to the device:
    • Two Phillips #00 4.5mm screws
    • Four Phillips #00 4.5mm screws
  11. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 11 中的图像 1,2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 11 中的图像 2,2
    • Lift and remove the fan and heat sink from the device.
    • When removing the fan, there will be an adhesive strip attached to the bottom. There may be some resistance as the device is being removed. Use a spudger to hold the adhesive down during removal.
  12. HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Motherboard: 步骤 12 中的图像 1,2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement, Motherboard: 步骤 12 中的图像 2,2
    • Remove all screws securing the motherboard to the device:
    • Ten Phillips #0 4.5mm screws
  13. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 13 中的图像 1,3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 13 中的图像 2,3 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 13 中的图像 3,3
    • Use the Reverse Tweezers to disconnect the speaker cables from the motherboard.
  14. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 14 中的图像 1,2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 14 中的图像 2,2
    • Slide out the ribbon wire from the motherboard
  15. HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 15 中的图像 1,2 HP Pavilion x360 14m-cd0005dx Motherboard Replacement: 步骤 15 中的图像 2,2
    • Gently lift the motherboard out of the device
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 676
