跳转到主内容
HP Pavilion x360 14m-cd0005dx Keyboard Replacement
你所需要的
  1. HP Pavilion x360 14m-cd0005dx Keyboard Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 2 中的图像 1,1
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 3 中的图像 1,2 HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 3 中的图像 2,2
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 4 中的图像 1,2 HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 4 中的图像 2,2
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 5 中的图像 1,3 HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 5 中的图像 2,3 HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 5 中的图像 3,3
    • Using the opening tool, carefully remove the bottom cover from the device.
  6. HP Pavilion x360 14m-cd0005dx Keyboard Replacement, Battery: 步骤 6 中的图像 1,3 HP Pavilion x360 14m-cd0005dx Keyboard Replacement, Battery: 步骤 6 中的图像 2,3 HP Pavilion x360 14m-cd0005dx Keyboard Replacement, Battery: 步骤 6 中的图像 3,3
    • Use a #00 Phillips screwdriver to remove:
    • Six 2.5 mm screws
  7. HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 7 中的图像 1,2 HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 7 中的图像 2,2
    • Carefully lift from the base and remove the battery.
  8. HP Pavilion x360 14m-cd0005dx Keyboard Replacement, Heat Sink and Fan: 步骤 8 中的图像 1,1
    • Remove the tape that secures the fan to the computer.
  9. HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 9 中的图像 1,2 HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Find the fan cable
    • Use the Reverse Tweezers to unplug the fan cable
  10. HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 10 中的图像 1,3 HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 10 中的图像 2,3 HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 10 中的图像 3,3
    • Remove all screws securing the fan to the device:
    • Two Phillips #00 4.5mm screws
    • Four Phillips #00 4.5mm screws
  11. HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 11 中的图像 1,2 HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 11 中的图像 2,2
    • Lift and remove the fan and heat sink from the device.
    • When removing the fan, there will be an adhesive strip attached to the bottom. There may be some resistance as the device is being removed. Use a spudger to hold the adhesive down during removal.
  12. HP Pavilion x360 14m-cd0005dx Keyboard Replacement, Keyboard: 步骤 12 中的图像 1,2 HP Pavilion x360 14m-cd0005dx Keyboard Replacement, Keyboard: 步骤 12 中的图像 2,2
    • Remove all screws securing the hinges to the device:
    • Four Phillips #0 4.5mm screws
    • After removing the hinge screws, it can be harder to turn the laptop. Be sure to not force it, but pressing on the hinge itself to make it move may help when manipulating the screen.
  13. HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 13 中的图像 1,2 HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 13 中的图像 2,2
    • Grab the ribbon wires by the edge of the socket and pull to remove them from the motherboard.
  14. HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 14 中的图像 1,1
    • Rotate the screen backwards until only the keyboard is visible.
  15. HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 15 中的图像 1,1
    • Run an Opening Tool along the edge of the device.
    • Pull the plastic keyboard up and away from the base of the laptop.
    • There is adhesive attaching the keyboard to the base of the laptop. Continue to pull the keyboard up and out; ignore the resistance.
    • Pull up on the metal casing of the keyboard below the keyboard's surface once a hand can adequately fit under the gap.
  16. HP Pavilion x360 14m-cd0005dx Keyboard Replacement: 步骤 16 中的图像 1,1
    • Gently raise the keyboard up and keep pulling to remove it from the base housing.
    • Do not pull just the top casing off. It is brittle and it may break. Ensure that the opening tool is beneath the keyboard in its entirety.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 6
过去 30 天: 30
总计 2,413
