跳转到主内容
HP Pavilion x360 14m-cd0005dx Back Cover Replacement
你所需要的
  1. HP Pavilion x360 14m-cd0005dx Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Turn off and shut down the computer.
    • Disconnect the power adapter and all external devices connected to the computer.
    • Do not work with the device powered on. It may result in bodily harm through electric shock.
  2. HP Pavilion x360 14m-cd0005dx Back Cover Replacement: 步骤 2 中的图像 1,1
    • Flip the device with the backplate up and with the hinge on the far side.
  3. HP Pavilion x360 14m-cd0005dx Back Cover Replacement: 步骤 3 中的图像 1,2 HP Pavilion x360 14m-cd0005dx Back Cover Replacement: 步骤 3 中的图像 2,2
    • Use the opening tool to remove the rubber feet attached to the bottom of the device.
  4. HP Pavilion x360 14m-cd0005dx Back Cover Replacement: 步骤 4 中的图像 1,2 HP Pavilion x360 14m-cd0005dx Back Cover Replacement: 步骤 4 中的图像 2,2
    • Remove all screws located on the bottom of the device:
    • Two Phillips #0 7.0mm screws
    • Three Phillips #00 4.5mm screws
    • Make sure to keep track of all screws removed from the device.
  5. HP Pavilion x360 14m-cd0005dx Back Cover Replacement: 步骤 5 中的图像 1,3 HP Pavilion x360 14m-cd0005dx Back Cover Replacement: 步骤 5 中的图像 2,3 HP Pavilion x360 14m-cd0005dx Back Cover Replacement: 步骤 5 中的图像 3,3
    • Using the opening tool, carefully remove the bottom cover from the device.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 33
总计 3,516
