跳转到主内容
HP Pavilion x360 14m-cd0003dx Touchpad Replacement
你所需要的
  1. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 步骤 2 中的图像 1,2 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 步骤 2 中的图像 2,2
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 步骤 3 中的图像 1,3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 步骤 3 中的图像 2,3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 步骤 3 中的图像 3,3
    • Remove the six 5 mm battery screws, and the battery can then be taken out.
  4. HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: 步骤 4 中的图像 1,3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: 步骤 4 中的图像 2,3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement, Touchpad: 步骤 4 中的图像 3,3
    • Lift the black tab on the ZIF connector, and gently pull the track pad ribbon cable free.
  5. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 步骤 5 中的图像 1,3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 步骤 5 中的图像 2,3 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 步骤 5 中的图像 3,3
    • Use a Phillips Head Screwdriver to remove the bottom 3 screws (5 mm).
    • Remove the metal plate that secures the touch pad.
  6. HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 步骤 6 中的图像 1,2 HP Pavilion x360 14m-cd0003dx Touchpad Replacement: 步骤 6 中的图像 2,2
    • Use a Phillips Head Screwdriver to unscrew top 3 screws (5 mm).
    • Remove touch pad.
结论
Elijah Jope
于03/22/22注册
376 声望
创作了3篇指南
团队
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 的会员
UMASSD-SINCLAIRE-S22S7G4
6 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 373
