跳转到主内容
HP Pavilion x360 14m-cd0003dx Screen Replacement
你所需要的
  1. HP Pavilion x360 14m-cd0003dx Screen Replacement, Screen: 步骤 1 中的图像 1,1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Screen Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to carefully separate the screen from the plastic frame.
    • Work along the top first, and then down the left and right sides.
  3. HP Pavilion x360 14m-cd0003dx Screen Replacement: 步骤 3 中的图像 1,1
    • The screen can then be separated from the frame and laid flat on top of the keyboard.
    • Do not pull and try to remove yet, as the screen is still connected by several cables.
  4. HP Pavilion x360 14m-cd0003dx Screen Replacement: 步骤 4 中的图像 1,2 HP Pavilion x360 14m-cd0003dx Screen Replacement: 步骤 4 中的图像 2,2
    • The next few steps involve disconnecting the screen from the laptop in several places.
    • The first place is connected to the left side of the thin blue board at the top.
    • Peel back the clear adhesive and remove the pin header from the port on the blue board.
  5. HP Pavilion x360 14m-cd0003dx Screen Replacement: 步骤 5 中的图像 1,2 HP Pavilion x360 14m-cd0003dx Screen Replacement: 步骤 5 中的图像 2,2
    • The next place is underneath the gray adhesive. Peel back this adhesive to expose the connection underneath.
    • Disconnect the gold pin header from its port.
  6. HP Pavilion x360 14m-cd0003dx Screen Replacement: 步骤 6 中的图像 1,1
    • Repeat Step 4 for the connection on the right side.
    • Peel the clear adhesive and remove connection.
  7. HP Pavilion x360 14m-cd0003dx Screen Replacement: 步骤 7 中的图像 1,3 HP Pavilion x360 14m-cd0003dx Screen Replacement: 步骤 7 中的图像 2,3 HP Pavilion x360 14m-cd0003dx Screen Replacement: 步骤 7 中的图像 3,3
    • Peel the thin gray adhesive strips.
    • Pull out the thin black cable underneath these strips. It is the same black cable that was disconnected in the previous steps.
  8. HP Pavilion x360 14m-cd0003dx Screen Replacement: 步骤 8 中的图像 1,1
    • After the cable has been disconnected, the screen can be removed.
结论
Elijah Jope
于03/22/22注册
376 声望
创作了3篇指南
团队
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 的会员
UMASSD-SINCLAIRE-S22S7G4
6 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 8
过去 30 天: 36
总计 632
