跳转到主内容
HP Pavilion x360 14m-cd0003dx Hinges Replacement
你所需要的
  1. HP Pavilion x360 14m-cd0003dx Hinges Replacement, Screen: 步骤 1 中的图像 1,1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 2 中的图像 1,1
    • Use a plastic opening tool to carefully separate the screen from the plastic frame.
    • Work along the top first, and then down the left and right sides.
  3. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 3 中的图像 1,1
    • The screen can then be separated from the frame and laid flat on top of the keyboard.
    • Do not pull and try to remove yet, as the screen is still connected by several cables.
  4. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 4 中的图像 1,2 HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 4 中的图像 2,2
    • The next few steps involve disconnecting the screen from the laptop in several places.
    • The first place is connected to the left side of the thin blue board at the top.
    • Peel back the clear adhesive and remove the pin header from the port on the blue board.
  5. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 5 中的图像 1,2 HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 5 中的图像 2,2
    • The next place is underneath the gray adhesive. Peel back this adhesive to expose the connection underneath.
    • Disconnect the gold pin header from its port.
  6. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 6 中的图像 1,1
    • Repeat Step 4 for the connection on the right side.
    • Peel the clear adhesive and remove connection.
  7. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 7 中的图像 1,3 HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 7 中的图像 2,3 HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 7 中的图像 3,3
    • Peel the thin gray adhesive strips.
    • Pull out the thin black cable underneath these strips. It is the same black cable that was disconnected in the previous steps.
  8. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 8 中的图像 1,1
    • After the cable has been disconnected, the screen can be removed.
  9. HP Pavilion x360 14m-cd0003dx Hinges Replacement, Hinges: 步骤 9 中的图像 1,1
    • Remove the three Phillip Head screws (5 mm)that hold in the bracket on each side.
  10. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 10 中的图像 1,1
    • Slide the frame down past the brackets on each side.
  11. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 11 中的图像 1,3 HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 11 中的图像 2,3 HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 11 中的图像 3,3
    • Lay the laptop flat on your working surface.
    • Flip it over to get access to the back panel.
    • Remove the back panel screws and take off the back cover.
  12. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 12 中的图像 1,2 HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 12 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the 5 mm screws from the hinges on each side inside the laptop.
  13. HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 13 中的图像 1,2 HP Pavilion x360 14m-cd0003dx Hinges Replacement: 步骤 13 中的图像 2,2
    • Remove the hinges from both sides of the laptop.
结论
另外一个人完成了本指南。
Elijah Jope
于03/22/22注册
376 声望
创作了3篇指南
团队
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 的会员
UMASSD-SINCLAIRE-S22S7G4
6 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 18
过去 30 天: 88
总计 2,178
