跳转到主内容
HP Pavilion x360 14m-cd0003dx Fan Replacement
你所需要的
  1. HP Pavilion x360 14m-cd0003dx Fan Replacement, Heat Sink and Fan: 步骤 1 中的图像 1,1
    • Turn off the computer.
    • Disconnect the power cord and any external devices connected to the computer.
    • Make sure the device is completely turned off or else you may risk injury through electric shock.
  2. HP Pavilion x360 14m-cd0003dx Fan Replacement: 步骤 2 中的图像 1,2 HP Pavilion x360 14m-cd0003dx Fan Replacement: 步骤 2 中的图像 2,2
    • Flip the device so that the back plate of the laptop is up.
    • Use a Phillips #0 screwdriver to remove the four 6 mm Phillips screws from the bottom cover.
    • You might have to use a spudger to remove any rubber bezels that cover the screws.
    • Pry off the back cover with the spudger tool.
  3. HP Pavilion x360 14m-cd0003dx Fan Replacement: 步骤 3 中的图像 1,2 HP Pavilion x360 14m-cd0003dx Fan Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the seven 5 mm screws that secure the fan and heatsink.
  4. HP Pavilion x360 14m-cd0003dx Fan Replacement: 步骤 4 中的图像 1,1
    • Peel back the retention tape that secures the heat sink assembly.
  5. HP Pavilion x360 14m-cd0003dx Fan Replacement: 步骤 5 中的图像 1,1
    • Disconnect the fan cable from the connector on the system board.
  6. HP Pavilion x360 14m-cd0003dx Fan Replacement: 步骤 6 中的图像 1,1
    • Remove the heat sink assembly from the device.
结论
2等其他人完成本指南。
Riley McMorrow
于03/22/22注册
240 声望
撰写一个指南
团队
UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 UMass Dartmouth, Team 7-4, Sinclaire Spring 2022 的会员
UMASSD-SINCLAIRE-S22S7G4
6 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 20
总计 456
