简介
If your HP Pavilion x360 14m-ba011dx laptop has lost the ability to connect to Wi-Fi or it experiences difficulty connecting to Wi-Fi, use this guide to replace the Wi-Fi card.
你所需要的
Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to expose the screws underneath.
Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:
Two 7.5 mm screws.
Three 5 mm screws.
One 6.5 mm screw.
Flip motherboard over to expose the Wi-Fi card.
Rotate the motherboard so the Wi-Fi card is closest to you.
Gently remove the Wi-Fi card from its slot.
一条评论
IS it possible to put a new wlan card with wifi 6 and bluetooth 5.0? For example this one? https://www.informatique.nl/206503/intel...
