简介
With this guide, the user will be able to access the RAM and either remove or add more RAM cards to the HP Pavilion x360 14m-ba011dx laptop. More RAM cards might be needed for your computer to run higher memory programs. The HP pavilion x360 14m-ba011dx laptop comes from the factory with an 8GB RAM card, however, there are 2 slots available for extra RAM capability.
你所需要的
Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to expose the screws underneath.
Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:
Two 7.5 mm screws.
Three 5 mm screws.
One 6.5 mm screw.
另外一个人完成了本指南。
