跳转到主内容
HP Pavilion x360 14-ba253cl Keyboard Replacement
你所需要的
  1. HP Pavilion x360 14-ba253cl Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Use the Jimmy to remove the footpads located at the bottom of the laptop.
  2. HP Pavilion x360 14-ba253cl Keyboard Replacement: 步骤 2 中的图像 1,1
    • Remove three 4.0mm Phillips #0 screws from the top of the cover.
    • Remove two 6.0mm Phillips #0 screws underneath each of the back footpads.
    • Remove one 4.mm Phillips #0 screw beneath the divot.
  3. HP Pavilion x360 14-ba253cl Keyboard Replacement: 步骤 3 中的图像 1,1
    • Turn the computer onto its base, with the computer open and the keys facing upward.
  4. HP Pavilion x360 14-ba253cl Keyboard Replacement: 步骤 4 中的图像 1,1
    • Use an opening pick to separate the keyboard from the base of the laptop.
  5. HP Pavilion x360 14-ba253cl Keyboard Replacement: 步骤 5 中的图像 1,1
    • Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
    • Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
    • Use the blue plastic tab on the ribbon cable to pull it out from the system board.
    • Remove the keyboard from the laptop.
结论
另外一个人完成了本指南。
Kristen Gismondi
于11/12/14注册
82,266 声望
创作了200篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了17,277篇指南
一条评论
Kristen, How is the keyboard mounted to the top panel?
Larry Levy - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 79
总计 6,988
