跳转到主内容
HP Pavilion x360 14-ba253cl Battery Replacement
你所需要的
  1. HP Pavilion x360 14-ba253cl Battery Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Use the Jimmy to remove the footpads located at the bottom of the laptop.
  2. HP Pavilion x360 14-ba253cl Battery Replacement: 步骤 2 中的图像 1,1
    • Remove three 4.0mm Phillips #0 screws from the top of the cover.
    • Remove two 6.0mm Phillips #0 screws underneath each of the back footpads.
    • Remove one 4.mm Phillips #0 screw beneath the divot.
  3. HP Pavilion x360 14-ba253cl Battery Replacement: 步骤 3 中的图像 1,1
    • Turn the computer onto its base, with the computer open and the keys facing upward.
  4. HP Pavilion x360 14-ba253cl Battery Replacement: 步骤 4 中的图像 1,1
    • Use an opening pick to separate the keyboard from the base of the laptop.
  5. HP Pavilion x360 14-ba253cl Battery Replacement: 步骤 5 中的图像 1,1
    • Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
    • Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
    • Use the blue plastic tab on the ribbon cable to pull it out from the system board.
    • Remove the keyboard from the laptop.
  6. HP Pavilion x360 14-ba253cl Battery Replacement, Battery: 步骤 6 中的图像 1,1
    • Remove six 3mm Phillips #00 screws around the perimeter of the battery.
  7. HP Pavilion x360 14-ba253cl Battery Replacement: 步骤 7 中的图像 1,1
    • Carefully lift the battery starting from the lower right corner and disconnect it from the system board.
结论
5等其他人完成本指南。
一条评论
Thanks, it was useful
Oleg - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 123
总计 8,355
