跳转到主内容
HP Pavilion x360 11-p110nr Speakers Replacement
你所需要的
  1. HP Pavilion x360 11-p110nr Speakers Replacement, Speakers: 步骤 1 中的图像 1,3 HP Pavilion x360 11-p110nr Speakers Replacement, Speakers: 步骤 1 中的图像 2,3 HP Pavilion x360 11-p110nr Speakers Replacement, Speakers: 步骤 1 中的图像 3,3
    • Eleven case screws are located on the bottom of the laptop. Two will be underneath the rubber feet.
    • Use a Phillips #0 screwdriver to remove all 6.7 mm screws from the bottom cover.
    • Carefully take the bottom cover off.
    • Don't force the bottom plate off. There will be a cable connecting the bottom plate to the rest of the laptop. If you pull too hard you risk damaging this cable.
  2. HP Pavilion x360 11-p110nr Speakers Replacement: 步骤 2 中的图像 1,3 HP Pavilion x360 11-p110nr Speakers Replacement: 步骤 2 中的图像 2,3 HP Pavilion x360 11-p110nr Speakers Replacement: 步骤 2 中的图像 3,3
    • Before fully removing the top cover, locate the cable that connects the audio controls.
    • Once located, lift the small black flap and carefully pull the cable out.
  3. HP Pavilion x360 11-p110nr Speakers Replacement: 步骤 3 中的图像 1,3 HP Pavilion x360 11-p110nr Speakers Replacement: 步骤 3 中的图像 2,3 HP Pavilion x360 11-p110nr Speakers Replacement: 步骤 3 中的图像 3,3
    • Remove the large cable connecting the battery to the main board
    • Caution: Lithium Ion batteries provide a risk of electrocution or fire if mishandled. Failure to disconnect the battery before removing the speakers could also lead to risk of electrocution.
  4. HP Pavilion x360 11-p110nr Speakers Replacement: 步骤 4 中的图像 1,3 HP Pavilion x360 11-p110nr Speakers Replacement: 步骤 4 中的图像 2,3 HP Pavilion x360 11-p110nr Speakers Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Locate the cable for the speakers and unplug, as shown.
    • If needed, use the tweezers to gently remove the cable from its connector.
  5. HP Pavilion x360 11-p110nr Speakers Replacement: 步骤 5 中的图像 1,3 HP Pavilion x360 11-p110nr Speakers Replacement: 步骤 5 中的图像 2,3 HP Pavilion x360 11-p110nr Speakers Replacement: 步骤 5 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the four 5.8 mm screws from the speakers.
    • The speakers are now not secured to the laptop.
  6. HP Pavilion x360 11-p110nr Speakers Replacement: 步骤 6 中的图像 1,3 HP Pavilion x360 11-p110nr Speakers Replacement: 步骤 6 中的图像 2,3 HP Pavilion x360 11-p110nr Speakers Replacement: 步骤 6 中的图像 3,3
    • Lift each speaker out of the laptop.
    • Carefully remove each speaker.
    • The speakers are connected to each other by a wire.
结论
Aeorrell
于03/27/23注册
433 声望
创作了3篇指南
团队
IUPUI, Team 1-2, Harley Spring 2023 IUPUI, Team 1-2, Harley Spring 2023 的会员
IUPUI-HARLEY-S23S1G2
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 72
