跳转到主内容
HP Pavilion x360 11-p110nr Battery Replacement
你所需要的
  1. HP Pavilion x360 11-p110nr Battery Replacement, Battery: 步骤 1 中的图像 1,2 HP Pavilion x360 11-p110nr Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • First, unplug the power cord from the power outlet and disconnect the charger.
    • Flip over the laptop.
    • Unscrew the back cover using the Phillips #0 screwdriver.
    • Deattach the cover carefully and do not remove the cover completely as there is a safety plastic that needs to be removed first.
    • Remove the blue safety plastic in an orthogonal motion from where it is inserted carefully.
  2. HP Pavilion x360 11-p110nr Battery Replacement: 步骤 2 中的图像 1,2 HP Pavilion x360 11-p110nr Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the five 1 mm screws connecting the battery to the base of the computer using a Phillips #0 screwdriver.
  3. HP Pavilion x360 11-p110nr Battery Replacement: 步骤 3 中的图像 1,1
    • Carefully disconnect the three connectors by pulling them away from the slot.
    • If they seem hard to pull, try to wiggle them loose to making it easier to pull.
    • Pull out the battery after everything is disconnected.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 629
