跳转到主内容
HP Pavilion x360 11-p110nr Hard Drive Replacement
你所需要的
  1. HP Pavilion x360 11-p110nr  Hard Drive  Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Make sure the laptop is turned off, and the power cable is removed.
    • Leaving the laptop turned on can cause damage to the hardware and any stored data.
  2. HP Pavilion x360 11-p110nr  Hard Drive  Replacement: 步骤 2 中的图像 1,1
    • Turn the laptop over to access the backside of the computer.
    • Identify and confirm that the laptop is an HP Pavilion x360 11-p110nr.
    • Remove the nine screws from the back panel using a Phillips #0 screwdriver.
  3. HP Pavilion x360 11-p110nr  Hard Drive  Replacement: 步骤 3 中的图像 1,1
    • Remove the four screws holding in the hard drive compartment using a Phillips #0 screwdriver.
    • Pull the hard drive up and out to remove it from the compartment.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 19
总计 1,978
