跳转到主内容
HP Pavilion x2 10-n113dx Touch Pad Replacement
你所需要的
  1. HP Pavilion x2 10-n113dx Touch Pad Replacement, Touch Pad: 步骤 1 中的图像 1,2 HP Pavilion x2 10-n113dx Touch Pad Replacement, Touch Pad: 步骤 1 中的图像 2,2
    • Separate the screen from the keyboard.
  2. HP Pavilion x2 10-n113dx Touch Pad Replacement: 步骤 2 中的图像 1,1
    • Loosen the adhesive under the gray plastic bar using a heat pad or a heat gun.
    • Remove the gray plastic bar after 5 minutes of light heat with tweezers by pulling up.
  3. HP Pavilion x2 10-n113dx Touch Pad Replacement: 步骤 3 中的图像 1,1
    • Remove the 4 screws with a Phillips #0 screwdriver.
    • These 4 screws have a diameter of 4.3 mm and a height of 3.7 mm.
  4. HP Pavilion x2 10-n113dx Touch Pad Replacement: 步骤 4 中的图像 1,2 HP Pavilion x2 10-n113dx Touch Pad Replacement: 步骤 4 中的图像 2,2
    • Remove the rubber stoppers at the top left and right with tweezers.
    • Remove the screws at the top and right with at Phillips #0 screwdriver.
    • These two screws have a diameter of 5.3 mm and a height of 4.3 mm.
  5. HP Pavilion x2 10-n113dx Touch Pad Replacement: 步骤 5 中的图像 1,3 HP Pavilion x2 10-n113dx Touch Pad Replacement: 步骤 5 中的图像 2,3 HP Pavilion x2 10-n113dx Touch Pad Replacement: 步骤 5 中的图像 3,3
    • Pry open the back case with a metal spudger.
    • Then pry open the back layer with the metal spudger.
  6. HP Pavilion x2 10-n113dx Touch Pad Replacement: 步骤 6 中的图像 1,2 HP Pavilion x2 10-n113dx Touch Pad Replacement: 步骤 6 中的图像 2,2
    • Fully take off the back panel by lifting up the panel.
  7. HP Pavilion x2 10-n113dx Touch Pad Replacement: 步骤 7 中的图像 1,2 HP Pavilion x2 10-n113dx Touch Pad Replacement: 步骤 7 中的图像 2,2
    • Pop open the ribbon cable piece on the touch pad with the blue plastic spudger.
    • Remove the ribbon cable with tweezers by pulling it out.
  8. HP Pavilion x2 10-n113dx Touch Pad Replacement: 步骤 8 中的图像 1,2 HP Pavilion x2 10-n113dx Touch Pad Replacement: 步骤 8 中的图像 2,2
    • Remove 4 screws with at Phillips #0 screwdriver. All 4 screws have a diameter of 4.3 mm and a height of 3.7 mm.
    • Lift the tape shown with orange boxes with tweezers.
    • Remove metal bar with a blue spudger.
  9. HP Pavilion x2 10-n113dx Touch Pad Replacement: 步骤 9 中的图像 1,3 HP Pavilion x2 10-n113dx Touch Pad Replacement: 步骤 9 中的图像 2,3 HP Pavilion x2 10-n113dx Touch Pad Replacement: 步骤 9 中的图像 3,3
    • Lift up the touch pad by the metal edge with a blue plastic spudger.
    • Remove the touch pad from the computer.
结论
Cayla Skaggs
于04/01/19注册
337 声望
创作了2篇指南
团队
IUPUI, Team S1-G4, Harley Spring 2019 IUPUI, Team S1-G4, Harley Spring 2019 的会员
IUPUI-HARLEY-S19S1G4
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 700
