跳转到主内容
HP Pavilion x2 10-n113dx Hinge Replacement
你所需要的
  1. HP Pavilion x2 10-n113dx Hinge Replacement, Hinge: 步骤 1 中的图像 1,2 HP Pavilion x2 10-n113dx Hinge Replacement, Hinge: 步骤 1 中的图像 2,2
    • Separate the screen from the keyboard.
  2. HP Pavilion x2 10-n113dx Hinge Replacement: 步骤 2 中的图像 1,2 HP Pavilion x2 10-n113dx Hinge Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Remove the grey rubber bar using plastic spudger or tweezers, exposing the four screw heads.
    • The rubber bar is attached with an adhesive. A heat pad may be required to melt the adhesive and allow for easier removal.
  3. HP Pavilion x2 10-n113dx Hinge Replacement: 步骤 3 中的图像 1,1
    • Unscrew the four screws using the Phillips #0 screwdriver.
    • All four of these screws have a diameter of 4.3 mm and a height of 3.7 mm.
  4. HP Pavilion x2 10-n113dx Hinge Replacement: 步骤 4 中的图像 1,2 HP Pavilion x2 10-n113dx Hinge Replacement: 步骤 4 中的图像 2,2
    • Remove the circular rubber tabs exposing the screw heads below.
    • A heat pad may be required to melt the tab adhesive and allow for easier removal.
    • Unscrew the two screws using the Phillips #0 screwdriver.
    • These two screws are 5.3 mm in diameter and 4.3 mm in height.
  5. HP Pavilion x2 10-n113dx Hinge Replacement: 步骤 5 中的图像 1,3 HP Pavilion x2 10-n113dx Hinge Replacement: 步骤 5 中的图像 2,3 HP Pavilion x2 10-n113dx Hinge Replacement: 步骤 5 中的图像 3,3
    • Once all screws have been removed, gently pry open the back casing using a metal spudger.
    • Be sure to use the spudger at the marked locations to avoid damage to the casing.
  6. HP Pavilion x2 10-n113dx Hinge Replacement: 步骤 6 中的图像 1,2 HP Pavilion x2 10-n113dx Hinge Replacement: 步骤 6 中的图像 2,2
    • Completely remove the back casing.
  7. HP Pavilion x2 10-n113dx Hinge Replacement: 步骤 7 中的图像 1,1
    • Unscrew the four screws located at the marked locations using the Phillips #0 screwdriver.
    • All fours of these screws have a 7.0 mm diameter an a 2.5 mm height.
  8. HP Pavilion x2 10-n113dx Hinge Replacement: 步骤 8 中的图像 1,1
    • Remove adhesive that secures the ribbon cable using tweezers.
  9. HP Pavilion x2 10-n113dx Hinge Replacement: 步骤 9 中的图像 1,3 HP Pavilion x2 10-n113dx Hinge Replacement: 步骤 9 中的图像 2,3 HP Pavilion x2 10-n113dx Hinge Replacement: 步骤 9 中的图像 3,3
    • Using a plastic spudger, flip open the switch for the connection port, allowing the ribbon cable to be removed.
  10. HP Pavilion x2 10-n113dx Hinge Replacement: 步骤 10 中的图像 1,3 HP Pavilion x2 10-n113dx Hinge Replacement: 步骤 10 中的图像 2,3 HP Pavilion x2 10-n113dx Hinge Replacement: 步骤 10 中的图像 3,3
    • Gently lift the hinge from the attachment points as shown in the picture.
    • Tweezers can be also be used to ensure the ribbon cable does not get damaged in the process.
    • The hinge can now be completely separated.
结论
Ajay Panuganti
于04/01/19注册
181 声望
撰写一个指南
团队
IUPUI, Team S1-G4, Harley Spring 2019 IUPUI, Team S1-G4, Harley Spring 2019 的会员
IUPUI-HARLEY-S19S1G4
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 1,123
