跳转到主内容
HP Pavilion x2 10-n113dx Hinge Connector Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. HP Pavilion x2 10-n113dx Hinge Connector Replacement, Battery: 步骤 1 中的图像 1,3 HP Pavilion x2 10-n113dx Hinge Connector Replacement, Battery: 步骤 1 中的图像 2,3 HP Pavilion x2 10-n113dx Hinge Connector Replacement, Battery: 步骤 1 中的图像 3,3
    • Before starting, please turn off your laptop.
    • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
  2. HP Pavilion x2 10-n113dx Hinge Connector Replacement: 步骤 2 中的图像 1,2 HP Pavilion x2 10-n113dx Hinge Connector Replacement: 步骤 2 中的图像 2,2
    • Gently lift and remove the display panel from the assembly.
    • Remove the translucent yellow tape that covers the battery connector on the mainboard.
    • The tape will be in the way for a future step.
  3. HP Pavilion x2 10-n113dx Hinge Connector Replacement: 步骤 3 中的图像 1,3 HP Pavilion x2 10-n113dx Hinge Connector Replacement: 步骤 3 中的图像 2,3 HP Pavilion x2 10-n113dx Hinge Connector Replacement: 步骤 3 中的图像 3,3
    • Flip up the small white colored locking flap using the tip of a spudger or your fingernail. Then the ribbon cable can be removed easily without much effort.
    • Carefully disconnect the white ribbon cable from the mainboard.
  4. HP Pavilion x2 10-n113dx Hinge Connector Replacement: 步骤 4 中的图像 1,3 HP Pavilion x2 10-n113dx Hinge Connector Replacement: 步骤 4 中的图像 2,3 HP Pavilion x2 10-n113dx Hinge Connector Replacement: 步骤 4 中的图像 3,3
    • Carefully disconnect the battery cable from its connector on the mainboard.
  5. HP Pavilion x2 10-n113dx Hinge Connector Replacement: 步骤 5 中的图像 1,3 HP Pavilion x2 10-n113dx Hinge Connector Replacement: 步骤 5 中的图像 2,3 HP Pavilion x2 10-n113dx Hinge Connector Replacement: 步骤 5 中的图像 3,3
    • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
    • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
    • Remove the battery from the device.
  6. HP Pavilion x2 10-n113dx Hinge Connector Replacement, Screen: 步骤 6 中的图像 1,3 HP Pavilion x2 10-n113dx Hinge Connector Replacement, Screen: 步骤 6 中的图像 2,3 HP Pavilion x2 10-n113dx Hinge Connector Replacement, Screen: 步骤 6 中的图像 3,3
    • Using the Phillips #0 screwdriver, carefully remove the 21 screws that hold the screen to the display panel. 3.32 mm head, 3.99 mm length (RED) , 2.82 head 3.5 mm length (YELLOW), and 4.15 mm head, 2.35 mm length (BLUE).
    • 3.32 mm head, 3.99 mm length.
    • 2.82 head 3.5 mm length.
    • 4.15 mm head, 2.35 mm length.
  7. HP Pavilion x2 10-n113dx Hinge Connector Replacement: 步骤 7 中的图像 1,3 HP Pavilion x2 10-n113dx Hinge Connector Replacement: 步骤 7 中的图像 2,3 HP Pavilion x2 10-n113dx Hinge Connector Replacement: 步骤 7 中的图像 3,3
    • Very carefully lift the circuit board in order to keep everything attached. Be careful with any cables that may still be connected.
  8. HP Pavilion x2 10-n113dx Hinge Connector Replacement, Hinge connector: 步骤 8 中的图像 1,2 HP Pavilion x2 10-n113dx Hinge Connector Replacement, Hinge connector: 步骤 8 中的图像 2,2
    • Use the Phillips #0 screwdriver to unscrew 2 screws 2.82 mm head 3.5 mm length from the hinge connector
  9. HP Pavilion x2 10-n113dx Hinge Connector Replacement: 步骤 9 中的图像 1,2 HP Pavilion x2 10-n113dx Hinge Connector Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use the tweezers to gently remove the white pogo board ribbon from the hinge connector.
  10. HP Pavilion x2 10-n113dx Hinge Connector Replacement: 步骤 10 中的图像 1,2 HP Pavilion x2 10-n113dx Hinge Connector Replacement: 步骤 10 中的图像 2,2
    • Gently remove the hinge connector from the display panel.
结论
另外一个人完成了本指南。
David Zambrano
于09/28/17注册
822 声望
创作了5篇指南
团队
USF Tampa, Team S13-G4, Boczar Fall 2017 USF Tampa, Team S13-G4, Boczar Fall 2017 的会员
USFT-BOCZAR-F17S13G4
4 名成员
创作了5篇指南
一条评论
THANK YOU SO MUTCH !!! My keyboard was broken but this is just that the cable wasn’t connected ! but i have only make step 1,2,3 and 4
baptiste.r1807 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 649
