跳转到主内容
HP Pavilion x2 10-n113dx Camera Replacement
你所需要的
  1. HP Pavilion x2 10-n113dx Camera Replacement, Camera: 步骤 1 中的图像 1,3 HP Pavilion x2 10-n113dx Camera Replacement, Camera: 步骤 1 中的图像 2,3 HP Pavilion x2 10-n113dx Camera Replacement, Camera: 步骤 1 中的图像 3,3
    • Separate the screen from the keyboard.
    • The keyboard and screen are held together via magnets.
    • Open the device and pull the screen parallel to its face.
  2. HP Pavilion x2 10-n113dx Camera Replacement: 步骤 2 中的图像 1,3 HP Pavilion x2 10-n113dx Camera Replacement: 步骤 2 中的图像 2,3 HP Pavilion x2 10-n113dx Camera Replacement: 步骤 2 中的图像 3,3
    • Separate the screen from body of the computer with a blue spudger.
    • Using a plastic spudger, gently begin separating the face from the body.
    • Separate each side gently.
  3. HP Pavilion x2 10-n113dx Camera Replacement: 步骤 3 中的图像 1,2 HP Pavilion x2 10-n113dx Camera Replacement: 步骤 3 中的图像 2,2
    • Once each edge has been separated, gently lift the face (screen) from the back.
    • Be sure to not do so quickly or you risk tearing the keyboard ribbon cable.
    • Rotate the device 180 degrees for the following steps.
  4. HP Pavilion x2 10-n113dx Camera Replacement: 步骤 4 中的图像 1,2 HP Pavilion x2 10-n113dx Camera Replacement: 步骤 4 中的图像 2,2
    • Follow the attached ribbon cable to the circuit board of the device.
    • On the side of the ribbon cable, use a small plastic spudger to pop open this plastic lock and gently pull in the direction of the cable to remove.
    • Gently lift up on the battery connector just below the earlier removed ribbon cable to remove.
  5. HP Pavilion x2 10-n113dx Camera Replacement: 步骤 5 中的图像 1,2 HP Pavilion x2 10-n113dx Camera Replacement: 步骤 5 中的图像 2,2
    • Unscrew and remove each of the four indicated screws using the Phillips #0 screwdriver.
    • Begin with the bottom left 4.5mm diameter screw.
    • Continue to the remaining three 2.0 mm diameter screws.
    • Once all four screws have been removed lift the battery from the device using the indicated pull tab along the top edge.
  6. HP Pavilion x2 10-n113dx Camera Replacement: 步骤 6 中的图像 1,3 HP Pavilion x2 10-n113dx Camera Replacement: 步骤 6 中的图像 2,3 HP Pavilion x2 10-n113dx Camera Replacement: 步骤 6 中的图像 3,3
    • Using a small blue plastic spudger pop off the two speaker wires from the circuit board.
    • Once removed from the board carefully move the wires from the raised clips on the metal plating.
  7. HP Pavilion x2 10-n113dx Camera Replacement: 步骤 7 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove the 4.5mm screw from the camera circuit board.
    • Using a plastic spudger flip up the two rubber covers to the right and left of the 4.5mm screw.
  8. HP Pavilion x2 10-n113dx Camera Replacement: 步骤 8 中的图像 1,2 HP Pavilion x2 10-n113dx Camera Replacement: 步骤 8 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Carefully remove the ribbon cable from the camera circuit board with tweezers.
    • Carefully remove the wire mesh tape from the metal plating using tweezers.
  9. HP Pavilion x2 10-n113dx Camera Replacement: 步骤 9 中的图像 1,2 HP Pavilion x2 10-n113dx Camera Replacement: 步骤 9 中的图像 2,2
    • Using a plastic spudger remove the camera circuit board from the device.
结论
Cayla Skaggs
于04/01/19注册
337 声望
创作了2篇指南
团队
IUPUI, Team S1-G4, Harley Spring 2019 IUPUI, Team S1-G4, Harley Spring 2019 的会员
IUPUI-HARLEY-S19S1G4
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 459
