跳转到主内容
HP Pavilion x2 10-n113dx Mainboard Replacement
你所需要的
  1. HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: 步骤 1 中的图像 1,3 HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: 步骤 1 中的图像 2,3 HP Pavilion x2 10-n113dx  Mainboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Before starting, please turn off your laptop.
    • Using the blue plastic opening tool or a flat bladed tool, carefully slide the blade in between the display panel and gently slide to prop open the assembly.
  2. HP Pavilion x2 10-n113dx  Mainboard Replacement: 步骤 2 中的图像 1,2 HP Pavilion x2 10-n113dx  Mainboard Replacement: 步骤 2 中的图像 2,2
    • Gently lift and remove the display panel from the assembly.
    • Remove the translucent yellow tape that covers the battery connector on the mainboard.
    • The tape will be in the way for a future step.
  3. HP Pavilion x2 10-n113dx  Mainboard Replacement: 步骤 3 中的图像 1,3 HP Pavilion x2 10-n113dx  Mainboard Replacement: 步骤 3 中的图像 2,3 HP Pavilion x2 10-n113dx  Mainboard Replacement: 步骤 3 中的图像 3,3
    • Flip up the small white colored locking flap using the tip of a spudger or your fingernail. Then the ribbon cable can be removed easily without much effort.
    • Carefully disconnect the white ribbon cable from the mainboard.
  4. HP Pavilion x2 10-n113dx  Mainboard Replacement: 步骤 4 中的图像 1,3 HP Pavilion x2 10-n113dx  Mainboard Replacement: 步骤 4 中的图像 2,3 HP Pavilion x2 10-n113dx  Mainboard Replacement: 步骤 4 中的图像 3,3
    • Carefully disconnect the battery cable from its connector on the mainboard.
  5. HP Pavilion x2 10-n113dx  Mainboard Replacement: 步骤 5 中的图像 1,3 HP Pavilion x2 10-n113dx  Mainboard Replacement: 步骤 5 中的图像 2,3 HP Pavilion x2 10-n113dx  Mainboard Replacement: 步骤 5 中的图像 3,3
    • Using the Phillips #0 screwdriver, carefully remove the 4 corner screws that hold the battery to the display panel.
    • 3 screws are 3.12 mm head, 2.40 mm length, and 1 screw is 5.85mm head, 2.5mm length.
    • Remove the battery from the device.
    How do you replace those magnets that help snap the laptop's into place?
    Alfa Orellana - 回复
  6. HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: 步骤 6 中的图像 1,3 HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: 步骤 6 中的图像 2,3 HP Pavilion x2 10-n113dx  Mainboard Replacement, Mainboard: 步骤 6 中的图像 3,3
    • To unscrew the mainboard use the Phillips #0 Screwdriver to remove two types of screws. Three 4.15mm head, 2.35mm in length screws and three 3.32mm head, 3.99mm in length screws
  7. HP Pavilion x2 10-n113dx  Mainboard Replacement: 步骤 7 中的图像 1,3 HP Pavilion x2 10-n113dx  Mainboard Replacement: 步骤 7 中的图像 2,3 HP Pavilion x2 10-n113dx  Mainboard Replacement: 步骤 7 中的图像 3,3
    • Remove mainboard.
结论
4等其他人完成本指南。
David Zambrano
于09/28/17注册
822 声望
创作了5篇指南
团队
USF Tampa, Team S13-G4, Boczar Fall 2017 USF Tampa, Team S13-G4, Boczar Fall 2017 的会员
USFT-BOCZAR-F17S13G4
4 名成员
创作了5篇指南
4条评论
Is this about the WiFi card? Because I cant see the SSD in any of your pictures.
Julian Lemmerich - 回复
So, where is the SSD? You’ve taken apart the whole logic board, but not evidence of any SSD module from your photos….
Matteo Repossi - 回复
It is not SSD drive, it is a motherboard
Da K - 回复
has anyone figured out where is the SSD (eMMC) by the way ?
Karantez Jegou - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 20
总计 7,402
