跳转到主内容
HP Pavilion g7-2275dx Battery Replacement
你所需要的
  1. HP Pavilion g7-2275dx Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. HP Pavilion g7-2275dx Battery Replacement: 步骤 2 中的图像 1,1
    • The battery is held in by a latch in the front and tabs in the back.
    • Slide the lock switch left, towards the center of the computer.
    • Lift up the battery, rotating it up and away from you, then pull it out.
    • To put the battery back in, line it up with the battery bay and the holes for the tabs. Then let the battery rotate towards you and press down until the latch engages and you hear a click.
结论
2等其他人完成本指南。
John Sutton
于04/24/14注册
1,566 声望
创作了8篇指南
团队
Cal Poly, Team 11-51, Amido Spring 2014 Cal Poly, Team 11-51, Amido Spring 2014 的会员
CPSU-AMIDO-S14S11G51
4 名成员
创作了21篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,328
