跳转到主内容
HP Pavilion g7-2023cl Service Door Replacement
你所需要的
  1. HP Pavilion g7-2023cl Service Door Replacement, Battery: 步骤 1 中的图像 1,1
    • Shut off your device and disconnect the power cord. Disconnect any external devices connected to the device.
    • Place your finger on the battery lock slider, press toward the center of the laptop to unlock the battery.
    • The lock will make a click sound letting you know that the battery is unlocked.
  2. HP Pavilion g7-2023cl Service Door Replacement: 步骤 2 中的图像 1,3 HP Pavilion g7-2023cl Service Door Replacement: 步骤 2 中的图像 2,3 HP Pavilion g7-2023cl Service Door Replacement: 步骤 2 中的图像 3,3
    • Use your thumb to pry up the edge of the battery and lift it out of the device.
    • When replacing the battery, align the notch on the battery with the battery lock on the device. Gently press down on the battery until you hear the lock click, which signals that the battery is secure.
  3. HP Pavilion g7-2023cl Service Door Replacement, Service Door: 步骤 3 中的图像 1,2 HP Pavilion g7-2023cl Service Door Replacement, Service Door: 步骤 3 中的图像 2,2
    • Using a Phillips #0 screwdriver, loosen the service door screw.
    • This is a captive screw that will remain attached to the service door.
  4. HP Pavilion g7-2023cl Service Door Replacement: 步骤 4 中的图像 1,2 HP Pavilion g7-2023cl Service Door Replacement: 步骤 4 中的图像 2,2
    • Lift the service door up and away from the device.
结论
Thomas Maloney
于03/21/19注册
1,060 声望
创作了9篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 329
