跳转到主内容
HP Pavilion g7-2023cl Keyboard Replacement
你所需要的
  1. HP Pavilion g7-2023cl Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Shut off your device and disconnect the power cord. Disconnect any external devices connected to the device.
    • Place your finger on the battery lock slider, press toward the center of the laptop to unlock the battery.
    • The lock will make a click sound letting you know that the battery is unlocked.
  2. HP Pavilion g7-2023cl Keyboard Replacement: 步骤 2 中的图像 1,3 HP Pavilion g7-2023cl Keyboard Replacement: 步骤 2 中的图像 2,3 HP Pavilion g7-2023cl Keyboard Replacement: 步骤 2 中的图像 3,3
    • Use your thumb to pry up the edge of the battery and lift it out of the device.
    • When replacing the battery, align the notch on the battery with the battery lock on the device. Gently press down on the battery until you hear the lock click, which signals that the battery is secure.
  3. HP Pavilion g7-2023cl Keyboard Replacement, Service Door: 步骤 3 中的图像 1,2 HP Pavilion g7-2023cl Keyboard Replacement, Service Door: 步骤 3 中的图像 2,2
    • Using a Phillips #0 screwdriver, loosen the service door screw.
    • This is a captive screw that will remain attached to the service door.
  4. HP Pavilion g7-2023cl Keyboard Replacement: 步骤 4 中的图像 1,2 HP Pavilion g7-2023cl Keyboard Replacement: 步骤 4 中的图像 2,2
    • Lift the service door up and away from the device.
  5. HP Pavilion g7-2023cl Keyboard Replacement, Keyboard: 步骤 5 中的图像 1,3 HP Pavilion g7-2023cl Keyboard Replacement, Keyboard: 步骤 5 中的图像 2,3 HP Pavilion g7-2023cl Keyboard Replacement, Keyboard: 步骤 5 中的图像 3,3
    • Locate the screw that secures the keyboard.
    • It is near the RAM module and the screw hole is identified by a keyboard symbol with the text underneath it that reads M2.5×6.5.
  6. HP Pavilion g7-2023cl Keyboard Replacement: 步骤 6 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the Phillips M2.5×6.5 screw that secures the keyboard.
  7. HP Pavilion g7-2023cl Keyboard Replacement: 步骤 7 中的图像 1,2 HP Pavilion g7-2023cl Keyboard Replacement: 步骤 7 中的图像 2,2
    • Insert the pointy end of a spudger into the two keyboard release holes and press down to disengage the keyboard from the device.
    • The release holes are on the base enclosure identified by a keyboard symbol with the word "release" written next to it.
  8. HP Pavilion g7-2023cl Keyboard Replacement: 步骤 8 中的图像 1,1
    • Turn the device over and open the laptop.
  9. HP Pavilion g7-2023cl Keyboard Replacement: 步骤 9 中的图像 1,2 HP Pavilion g7-2023cl Keyboard Replacement: 步骤 9 中的图像 2,2
    • Use your fingers and grab the corner(s) of the keyboard and lift up towards the display panel.
    • Fold the keyboard over key side down onto the top cover so that it lays flat on the track pad.
  10. HP Pavilion g7-2023cl Keyboard Replacement: 步骤 10 中的图像 1,3 HP Pavilion g7-2023cl Keyboard Replacement: 步骤 10 中的图像 2,3 HP Pavilion g7-2023cl Keyboard Replacement: 步骤 10 中的图像 3,3
    • Locate the keyboard cable connector.
    • Using a plastic opening tool, flip up the locking tab on the Zero Insertion Force (ZIF) connector.
  11. HP Pavilion g7-2023cl Keyboard Replacement: 步骤 11 中的图像 1,2 HP Pavilion g7-2023cl Keyboard Replacement: 步骤 11 中的图像 2,2
    • Pull the keyboard ribbon cable out from the connector.
  12. HP Pavilion g7-2023cl Keyboard Replacement: 步骤 12 中的图像 1,1
    • Remove the keyboard from the device.
结论
Thomas Maloney
于03/21/19注册
1,060 声望
创作了9篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 267
