跳转到主内容
HP Pavilion g7-1368dx Keyboard Replacement
你所需要的
  1. HP Pavilion g7-1368dx Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the device over so that the lower case is facing up.
    • Slide the battery release latch. The battery will pop up.
  2. HP Pavilion g7-1368dx Keyboard Replacement: 步骤 2 中的图像 1,1
    • Lift and remove the battery from its compartment.
  3. HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,3 HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,3 HP Pavilion g7-1368dx Keyboard Replacement, Keyboard: 步骤 3 中的图像 3,3
    • Loosen the two Phillips #1 screws that connect the service panel to the device.
    • These are captive screws and cannot be fully removed. They will remain attached to the service panel.
    • Slide the service panel down and pull it up to remove.
  4. HP Pavilion g7-1368dx Keyboard Replacement: 步骤 4 中的图像 1,1
    • Remove the one 7 mm Phillips #1 screw securing the keyboard to the device.
  5. HP Pavilion g7-1368dx Keyboard Replacement: 步骤 5 中的图像 1,1
    • Flip over the device and open the screen.
  6. HP Pavilion g7-1368dx Keyboard Replacement: 步骤 6 中的图像 1,2 HP Pavilion g7-1368dx Keyboard Replacement: 步骤 6 中的图像 2,2
    • Flip the keyboard over and locate the black ribbon cable that attaches the keyboard to the device.
    • Using a plastic opening tool, flip up the white tab on the zero insertion force connector.
    • Disconnect the ribbon cable by sliding it out of the ZIF connector.
    • Remove the keyboard.
结论
Kianna Young
于01/16/19注册
109 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 285
