简介
This guide will show you how to replace the HP Pavilion g7-1368 hard drive. This process should take approximately 10 minutes using only a Phillips #1 screwdriver. Make sure to shut down the device before proceeding with the replacement.
你所需要的
Turn the device over so that the lower case is facing up.
Slide the battery release latch. The battery will pop up.
即将完成!
结论
另外一个人完成了本指南。
