跳转到主内容
HP Pavilion g7-1368dx Hard Drive Replacement
你所需要的
  1. HP Pavilion g7-1368dx  Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the device over so that the lower case is facing up.
    • Slide the battery release latch. The battery will pop up.
  2. HP Pavilion g7-1368dx  Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Lift and remove the battery from its compartment.
  3. HP Pavilion g7-1368dx  Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Loosen the two Phillips #1 screws that connect the service panel to the device.
    • These are captive screws and cannot be fully removed. They will remain attached to the service panel.
  4. HP Pavilion g7-1368dx  Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Slide the service panel down and pull it up to remove.
  5. HP Pavilion g7-1368dx  Hard Drive Replacement: 步骤 5 中的图像 1,2 HP Pavilion g7-1368dx  Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Locate the hard drive.
    • It is missing from the device pictured here.
    • Disconnect the cable connector by pulling it away from the hard drive.
    • Remove the hard drive from the device.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 312
